Bed Side Rail Cap System - NOW MADE FROM ALUMINUM
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by KB Voodoo, Nov 30, 2014.
  1. Mar 4, 2015 at 12:27 PM
    #81
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I will be making a batch without holes on top very soon.
  2. Mar 4, 2015 at 6:16 PM
    #82
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Just to add on to this I have had mine since last December time frame and haven't experienced any problems having the holes in the rails. If anything they might have their advantages in being yet another area to allow any collected water to evaporate out, and not only that but any bed rail cap designed like these is going to have a gap at the sides because of the radiused edge of the Tacoma bedsides so any water will just blow out or exit in some shape or form.
    And if it rains what is the difference in the tires kicking water all up into the bedsides and some rain going down into the holes?
    I also noticed the raised "reinforcement" portions on the "other" design and i could be any issue for anyone wanting to mount some sort of topper flat to the rail. If you don't plan on a topper or mounting something flat to the rails then no problem but I run a Bestop and wanted a flat rail to provide as best a water tight seal as possible. I'm not trashing anyone elses versions, just providing an honest observation running KB Voodoos product.
  3. Mar 4, 2015 at 6:47 PM
    #83
    lakerfan
    lakerfan Well-Known Member
    Doug
    Castaic,CA
    09 DBL CAB PRERUNNER SPORT,Mag Grey.
    Sway away 2.5 coilovers, Maxtrac spindles, Dakar rear leafs, 18x9 Moto metals.
    Chad,would you let me know when you do I definitely want a set without the holes.
    Spencer likes this.
  4. Mar 5, 2015 at 8:16 AM
    #84
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Will do. The weather is about to break around here, and there will be a flood of new parts as well.
  5. Mar 6, 2015 at 1:11 PM
    #85
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I have talked to my friend with the long bed, and we are getting together to measure it up....TONIGHT!!!!
    That's right, tonight. Parts will hit the plasma table as early as Monday, then get formed, then go to powder coat.
    If everything falls into place, the long bed side rail caps should be ready to ship in 7 to 10 days.
  6. Mar 6, 2015 at 2:03 PM
    #86
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    HORAY! Dibs on a set with no holes and un-coated? :D
  7. Mar 6, 2015 at 2:20 PM
    #87
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    No holes, PC, with extension we've talked about.
  8. Mar 8, 2015 at 8:55 AM
    #88
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Here is the link to pre-order the LONG BED SIDE RAIL CAPS
    1/8" thick, because 14 gauge is tin foil.
    TW promo code is TWSIDERAILSLB to save $10 off list price.
    The number of sets that I make will be based on how many pre-orders I get.
  9. Mar 8, 2015 at 6:12 PM
    #89
    lapoltba
    CT - 06076
    Any chance of a package deal with a tailgate cap? I'm about to click the button. :)
    *Edit*
    oops, just found it!
  10. Mar 9, 2015 at 9:59 AM
    #90
    Mach375
    Gasket material is 1/16" thick. How wide is it? Like does it cover the entire surface, or just 3/4"?
    Can we get 1/8" thick?
  11. Mar 9, 2015 at 10:19 AM
    #91
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The gasket is 1/16" thick x 1/2" wide.
    It will look like this:
    If you put 1/8" thick tape under it, you would be able to see the tape, so I don't recommend it.
  12. Mar 9, 2015 at 5:44 PM
    #92
    whitetaco02
    whitetaco02 Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    Without reading through the whole thread do you sell just the piece that goes over the tailgate, make sense?
    Reason I ask is I have a camper shell and it over extends past the plastic cap onto my paint and is starting to wear my paint off. I would need one that extends down probably an inch and a half to two inches past stock. Do you know what I am referring to?
    I would also want to make sure that the new steel piece wouldn't make contact with my paint so I assume that is what the gasket is for?
    I just read through it all and need a tailgate cap but I need it to extend further down about two inches. Would doing this cause any issues with closing the camper shell window?
  13. Mar 9, 2015 at 6:07 PM
    #93
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The outside lip on my cap extends down exactly one inch, but it would probably still alleviate your problem.
  14. Mar 11, 2015 at 4:08 AM
    #94
    whitetaco02
    Frank
    GA
    09 Tacoma 4x4
    How much for just the tailgate piece?
  15. Mar 11, 2015 at 4:44 AM
    #95
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It's $85 when you use the TW promo code: TWGATECAP
    Order here
  16. Mar 11, 2015 at 5:38 AM
    #96
    Dogdad
    Dogdad Well-Known Member
    Metairie,Louisiana
    2015 Pyrite Mica Double Cab
    Subbed
  17. Mar 11, 2015 at 5:50 AM
    #97
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Thirteen sets of long bed caps were plasma cut last night.
    They will be formed tonight, and then taken to my powder coat guru tomorrow night.
    Everything will be ready to ship Monday!!
    A little over half the batch was pre-ordered, so get them while they're hot.
  18. Mar 11, 2015 at 6:11 AM
    #98
    lapoltba
    CT - 06076
    Woooo hoo! Can't wait!
  19. Mar 11, 2015 at 6:18 AM
    #99
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  20. Mar 11, 2015 at 6:21 AM
    #100
    lapoltba
    CT - 06076
    I put the order in the other day including a tailgate cap when you first posted. After nagging you for the LB version did you really think I would miss out? :D
