Bed size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DaveInTexas, Aug 8, 2020.
  1. Aug 8, 2020 at 8:15 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Yeah I agree its a nice little feature they put in, although I'm yet to use it. If you were to use 1/2 as thick cross beams, whatever you lay in there will sit flush with the side ridge and also the wheel wells which is cool.
  2. Aug 8, 2020 at 8:51 PM
    Koches
    Koches Well-Known Member
    2020 Silver Sky Metallic Tacoma SR AC 4X2 2.7
    I’ll be sure to post when I put it to use
  3. Aug 9, 2020 at 1:56 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Had the same idea for my truck, except i couldn't load everything i wanted without removing the tonneau cover. Ended up buying a used 5'x10' utility trailer.
  4. Aug 9, 2020 at 3:16 PM
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    Check out how @tonered used the tailgate to support the cargo.
    tonered likes this.
  5. Aug 9, 2020 at 3:17 PM
    Koches
    How strong do you think this set up is? Thanks
  6. Aug 9, 2020 at 4:29 PM
    DaveInTexas
    DaveInTexas [OP] Member
    Texas
    03 Tundra; moving to Tacoma
    that's pretty cool; I see the tailgate at just the right angle to support the load.
    I have to wonder what the siderails are made of & how strong - metal? Plastic bed insert?
    Oh wait, no fishing rod so I guess it won't work. I am >200miles from a fish-bearing lake!
  7. Aug 9, 2020 at 4:53 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    As strong as I have needed. 12 4x10 sheets here:
    I bought the rod that same day and was snapping a pic for a friend. We've been fishing out of our kayaks since then.
    Malvolio likes this.
  8. Aug 9, 2020 at 5:04 PM
    jaro
    jaro Member
    2020 TRD Off-Road DCSB Magnetic Gray
    I ended up building something like this and it worked out great. Since I was hauling 4x8 sheets of drywall I was a little hesitant to just rely upon the two boards across the wheel wells. I don't know if it was needed, but I liked having the additional 2x4's on top running the length of the bed to help support it.
    Either way, it worked for hauling 8 sheets of 4x8 drywall. I now just keep the two 2x8's and 2x4's on my lumber shelf in the garage if I need to use them in the future.
    DaveInTexas[OP] and tonered like this.
  9. Aug 9, 2020 at 5:04 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    I have a Tacoma because I wanted a manual transmission and because I need to be able to fit down narrow trails. Tundra is better in basically every other way.
    tonered and zoo truck like this.
  10. Aug 9, 2020 at 5:49 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    True, but it will haul 4x8 with zero problems. Heck, I've hauled 52in wide pallets a few times. The Taco rocks, IMHO.
