bed speaker setup help
Discussion in 'Audio & Video' started by jcwood2, Jun 2, 2008.
  1. Jun 2, 2008 at 9:46 PM
    jcwood2
    jcwood2 [OP] Member
    Ozark, AL
    silver streak TRD sport prerunner
    Before I start, I apologize for my electronic ignorance. I'm 17 so this modding stuff is new to me and I know very little about electronics due to my lack of experience. I'm hoping to start learning though, just need a little help.:D
    Ok, so I found a thread on toyotanation in which a guy installed extra speakers in the storage compartments above the wheel wells in the bed. It sounds like a cool, cheap, useful, and easy mod for me to start out on. He installed cheap 3" speakers with a max of 60 watts. He ran them from the stock head unit by splicing the rear speaker wire I think? link:http://www.toyotanation.com/forum/showthread.php?t=196194&highlight=bed+speakers
    I could probably do that on my own, but he has very little info on how he wired them.
    1. I've heard you have to wire the speakers in series to raise the ohms to 8 to avoid wiring them parallel, lowering the ohms to 2 which the factory head unit can't handle. Is this correct?
    2. Would running them off of the rear speakers wire work out ok? I don't want to buy an amp.
    3. I would like to run speakers that are bigger, so is there a limit on the amount of watts that would work?
    4. How would I wire a switch in the bed to turn the speakers on/off and also if possible the in-cab speakers on/off?
    Any answers to any of my questions would be great. :thumbsup:
  2. Jun 2, 2008 at 10:15 PM
    lineberw
    lineberw Well-Known Member
    Summerville, SC
    TRD 4x4
    Hey your fine adding some more speakers in the rear storage compartments as long as you just want speakers in your bed, not expecting them to be terribly loud is what I mean. It's an awesome idea if you tailgate. I wouldn't put anything more than a 6.5" coaxial speaker though. There is a hole behind the rear panel in your truck that you can push the wires out and run them to the back of the bed. Just tie into/tap off your rear door speakers and you'll be fine.
  3. Jun 3, 2008 at 11:40 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    You are correct in that you should not wire them in parallel to the existing speakers due to lowering the resistance to an unstable value. However, know that by wiring in series you will be reducing the total wattage output of the HU by half (what is probably only 15-20w will effectively be 7-10w). You are much better off buying a cheap amplifier and a switch to turn the bed speakers on and off.
    Doing something small and cheap is both safer and will likely give you significantly better results. If you want more information, just ask.
  4. Jun 3, 2008 at 11:48 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I would undo my back pair of speakers (in the door) and extend those wires to the bed. Then I would fade all the music forward when I want to turn them off.
  5. Jun 3, 2008 at 1:32 PM
    jcwood2
    jcwood2 [OP] Member
    Ozark, AL
    hey sooner, what type of amp and what kind of price would a new/used one run?
  6. Jun 3, 2008 at 2:30 PM
    jcwood2
    jcwood2 [OP] Member
    Ozark, AL
    now that I think about it, thats a great idea lsocoee. But is there a way I can keep the rear door speakers wired and put something to switch the current from the rear dooe speakers to the bed speakers? That would work out pretty well.
  7. Jun 3, 2008 at 2:41 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Try out your stereo with it faded to the front for a week and see if you like it. I like mine that way.
    If you don't, you could always get an A/B switcher. I'm assuming a home audio switcher would work fine. I'm no audiophile, but I got a pretty cheap one from Amazon for my house's speakers and it sounds decent.
    Mine was a pyle PSS4 for 4 speaker pairs.
  8. Jun 3, 2008 at 9:55 PM
    jcwood2
    jcwood2 [OP] Member
    Ozark, AL
    Anyone know the stock speaker specs so I can look for some similar ones for the best compatibility with the stock HU?
