Bed Step
Discussion in '4th Gen. Tacomas (2024+)' started by drooler, Apr 5, 2025.
  1. Apr 5, 2025 at 8:01 PM
    drooler
    drooler [OP] New Member
    25 Sport Premium
    I purchased a bed step (Amazon) and right out of the gate, I can't get the supplied M10 bolts to fit in the holes in the frame. Specifically, the first bolt that goes in specifically where the step assembly slides over before you tighten down and insert the other two bolts.
    One hole seems to be ok, another hole allows the bolt to enter about halfway before stopping (not too sure I want to tighten it down for fear of stripping the inner threads) and that first hole mentioned above, i can't get the threads to start.
    Anybody come across this yet with the aftermarket steps?
  2. Apr 5, 2025 at 8:50 PM
    Frenchy_123
    Frenchy_123 New Member
    Blake
    Portland, Oregon
    2024 Tacoma TRD Offroad
    Same thing happened to me, so I reached my phone up and took a picture of the bolt holes and I found slag in two locations. I took the truck to a Toyota dealership close to where I live and they said they would have to charge me to remove the slag - they won't cover it under warranty. I took it to another dealership since I was on the road and they took care of it for me and installed the step for me. An impact wrench will go right through the slag. I can't seem to find the pictures that I had.
  3. Apr 5, 2025 at 9:01 PM
    wfxt
    wfxt Well-Known Member
    The Empire State
    2025 Underground THLB (2021 MGM T4R Pro)
    Seriously, a dealer refused to help you out with that? Terrible. Good to look out for.
  4. Apr 5, 2025 at 9:28 PM
    chuychanga
    chuychanga Well-Known Member
    2000 LX470, 2006 Tacoma Prerunner, 2023 Tacoma Off-Road
    Tequila helps with that.
    wfxt and bbartol like this.
  5. Apr 5, 2025 at 10:01 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Get a tap and trace the threads don’t force the bolt in you could break the bolt off.
    TACODOC1 likes this.
  6. Apr 6, 2025 at 3:06 PM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    That's what I would do...
    t0p_d0g[QUOTED] likes this.
  7. Apr 7, 2025 at 10:05 AM
    ZigSchwartz
    ZigSchwartz Well-Known Member
    Zig
    Boston, Mass.
    2024 Tacoma SR5 / underground
    I had the same issue when I installed my bed step. Took a couple minutes to re-tap the threads. I happen to own a full tap & die set but you can pick up just a small metric tap kit on Amazon or at Home Depot for less than $15.
    https://www.amazon.com/dp/B07FKDMWWH
    I have an older Gearwrench kit similar to this one:
    https://www.amazon.com/dp/B000HBDW48
    Like others here said, don't force the bolt itself through the slag and definitely don't use an impact driver. If the bolt snaps you have a whole different problem to solve.
  8. Apr 9, 2025 at 10:17 PM
    drooler
    25 Sport Premium
    Good to know- thanks for the info.
    What's the thread size aside from the M10- i'm assuming 1 for Fine?
