Bed stiffeners that don't require drilling
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PolakTaco, Jun 19, 2023.
  1. Jun 19, 2023 at 7:59 PM
    PolakTaco
    PolakTaco [OP] Well-Known Member
    FL
    2022 Tacoma SR5 4x4 V6
    Just like the title, anyone out there makes bed stiffeners that don't require drilling and instead use preexisting holes?
  2. Jun 19, 2023 at 8:12 PM
    blackZEBRA
    blackZEBRA Well-Known Member
    California
    '23 TRD OR DCLB
    you can buy any kind and use the factory mounts and opt out of drilling
    drizzoh and Junkhead like this.
  3. Jun 19, 2023 at 8:14 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I have been using Total Chaos bed stiffeners and have only been using the factory bolt holes, have not drilled for the additional bolts. I do not have anything mounted on top of the bed rails.
    Junkhead and musicisevil like this.
  4. Jun 20, 2023 at 5:24 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    This may be a dumb question, but if you don't drill doesn't that defeat their purpose? If they aren't attached to anything other than the composite bed how is that going to prevent flexing?
  5. Jun 20, 2023 at 5:42 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    If you want max effect, I would just bite the bullet and drill the bed. If your concern is returning to stock for resale purposes then I wouldn’t even install them. The only usable hole on the vertical side of the bed structure are small m6 holes. If your concern is rust or something just make sure all the holes are painted up before running bolts. I’ve cut holes in metal on just about all of my last few Toyotas and as long as you paint things it’s not an issue. You can even top coat from the rear side of the mounts with fluid film or something for extra corrosion protection.
    I think they mean just using say the bed bolt location and then the 1 or 2 m6 bolt holes at the top edge of that rear metal section of the bed.
    CrashZone likes this.
  6. Jun 20, 2023 at 6:08 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    OK that makes more sense. Thanks for the clarification :)
  7. Jun 20, 2023 at 6:12 AM
    PolakTaco
    FL
    Thanks for replies.
    I'm not concerned about resale as I'm planning to keep this truck for many years. I live in Florida and my main concern was rust, especially with how bad humidity is here.
    I ordered softopper and getting bed rack as well. I also build drawers that will go in the back. Pretty sure I will need to install bed stiffeners.
  8. Jun 20, 2023 at 6:16 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    As @JdevTac said, paint the holes with some rust proof paint after drilling. Since none if it will be visible once you put everything back together you can use some Rustoleum or similar.
    MR E30 likes this.
  9. Jun 20, 2023 at 9:02 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    Why is rust a concern? I thought you only had to drill through the composite bed, not any metal?
    OG_Tacoma likes this.
  10. Jun 20, 2023 at 9:05 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    You don't drill through any composite. You drill through the metal on the vertical supports just inside the tail lights. I just drilled mine and used a little spray paint to cover the raw metal. Then once the stiffeners were installed, I coated the entire inside of the tail light bucket with HDMP from Amsoil. I'll probably reapply when I coat the frame annually.
    soundman98 likes this.
  11. Jun 20, 2023 at 9:07 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Just drill the 2 holes and be done with it. If bed stiffeners weren't already useless, they'd most definitely be only attaching them to the floor side.
    Sierrahunter and Stevie17 like this.
  12. Jun 20, 2023 at 9:10 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i would question if they can accomplish the task if its not drilled
  13. Jun 20, 2023 at 2:53 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yes, got mine from Amazon. Uses 3 factory bolts.
    Mbtstaco, Stevie17 and FL_TRD Sport like this.
  14. Jun 20, 2023 at 3:03 PM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    There are no holes on the vertical except for the one at the very top. Did you even have to take the tail light out to put those on?
  15. Jun 20, 2023 at 3:08 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Nope. 1 bolt on the top of vertical part and 2 bolts on the horizontal bottom part, very simple install.
    CrashZone and Stevie17 like this.
  16. Jun 20, 2023 at 3:24 PM
    WorstCaseOntario
    WorstCaseOntario Well-Known Member
    Graeme
    Toronto
    2022 Black Tacoma TRD OR Access Cab
    Dude I'm in Ontario, the rust capital of the world and drilled to install mine. Just slap some paint on the holes before you install and spray her down with some rust preventative spray every once in a while. She'll be fine.
  17. Jun 20, 2023 at 4:59 PM
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    I got the hooke road version of these off Amazon. A few people sell them. I liked the finish on hooks roads version better. There all the same style and function they were on sale for $68.
  18. Jun 20, 2023 at 5:57 PM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Sold. Just ordered from Amazon. For $59 I'll give them a shot, especially when I don't have pull the tail lights out and drill. Time will tell if they work with just one bolt.
  19. Jun 20, 2023 at 6:12 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I likely wouldn't have made this month's TW calendar if I had bed stiffeners :anonymous:
    WorstCaseOntario likes this.
  20. Jun 20, 2023 at 6:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shit that's your rig with the stuff bouncing out the bed?
    :rofl:
    I'm August
    Bent_Wrench and 3JOH22A[QUOTED] like this.
