bed storage cubbies fix?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SxDx, Jan 19, 2014.
  1. Jan 19, 2014 at 9:05 PM
    SxDx
    SxDx [OP] Well-Known Member
    TX
    Has anyone dealt with fixing storage cubbies that wont stay in place? Im referring to the cubbies over the wheel wells. The clips of the cubby on the passenger side of my bed are broken so every now and then on a bumpy road it falls out. Instead of buying a new cubby I was thinking epoxy? or maybe a better solution if anyone has one?
    Thanks in advance.
  2. Jan 19, 2014 at 9:12 PM
    Jeffsdeere
    Jeffsdeere Well-Known Member
    Jeff
    07 Tacoma DC4wd
    BAMF Sliders All Pro Rear Bumper 5100's @.85
    Double sided tape may work
  3. Jan 19, 2014 at 9:25 PM
    SxDx
    TX
    Tried it a while back. The thing is that the overlap on the edges is so small maybe around 1/4 inch that the 3m didn't have enough grip. That's whats kind of keeping me from doing the epoxy. Maybe some self tapping screws.
  4. Jan 20, 2014 at 6:12 AM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    Magnetic strips? Just guessin.
  5. Jan 20, 2014 at 6:15 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I used the gray double sided 3m tape, the 20lb one. It has worked just fine for me. I have taken the cubby off twice for mods and the tape has worked everytime I reapply it.
  6. Jan 20, 2014 at 6:20 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Unfortunately, I haven't needed to worry about it, because Toyota took them away from us on the newer trucks.
    But when I was lucky enough to have them, they never came off.
  7. Jan 20, 2014 at 7:14 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Odd, mine have never moved. I ignore them for the most part.
    Perhaps you could try using 2 - part marine epoxy, it's great stuff.
  8. Jan 20, 2014 at 7:18 AM
    pyrobobd
    pyrobobd Active Member
    Bob
    Southeast Colorado
    '07 basic truck
    Variable speed wiper switch
    I used flexible construction adhesive when mine took to falling out. Think 'Liquid Nails.' If I should want them out, the adhesive is flexible enough that I can pry and get a spatula in to break the adhesive.
  9. Jan 20, 2014 at 7:19 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    I'd epoxy the fuckers in
  10. Jan 20, 2014 at 7:29 AM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Rigid drying epoxy (like JB Weld) would likely not work well as it isn't flexible and will crack over time. I'd probably try the 3M Molding and Trim tape that's used to hold emblems on. It's stronger and more adhesive than regular double sided tape. (More expensive too.)
    I have a '14 DCLB and wish the small cubbies had doors that locked or at least were secured to keep them from falling off. I'll probably try to address that someday.
  11. Jan 20, 2014 at 8:45 AM
    SxDx
    TX
    Thanks for the suggestions. I will try some heavy duty double sided tape today.
    Will post back.
  12. Jan 20, 2014 at 8:48 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I just took em out and put some GE silicone 2 on the part that comes in contact with the bed and put em back.... Then sealed around the outside contact points.
    Been good for 6 months.
    Mine flew out when cornering a long time ago and I have no changed my driving habits, still havent come out since.
  13. Jan 20, 2014 at 8:58 AM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    I used the white 3M double sided sticky foam tape. Been almost a year and they are still in there. If one ever does fall out again I think I will use black silicone to put it back in place.
