Bed Storage Locks - Full DIY Write Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by floridaoccifer, Jun 30, 2010.
  1. Jun 30, 2010 at 4:25 PM
    floridaoccifer
    floridaoccifer [OP] Civil Servant
    Well after seeing various write ups on the bed storage lock idea I figured I would take things a step further and hopefully clear up the process. This is not a time consuming task and from start to finish I spent maybe 20 minutes converting/installing all three knobs.
    Items needed:
    - Phillips Screwdriver #2 bit
    - Utility Knife
    - Flush Cutters
    - Step Drill Bit
    - Power Drill
    - Adjustable Pliers (not pictured)
    - Loctite (if you feel the need / not pictured)
    - X3 Utility Cabinet Locks 5/8" (16mm - Less than $5.00 each at HomeDepot) - CHECK FOR MATCHING KEY NUMBERS!!
    Start by removing both doors. Turn over and remove all factory hardware (1 screw in each knob)
    Then locate the "tab" on each door. Take your flush cutters and carefully remove each one. Once they have been removed you can use your utility knife to clean up the surface making things completely flush.
    Then separate your locking components. The long locking rod works great as well as the 1/4" turn spacer. Place all other parts to the side, they will not be used/needed.
    Then place your step bit into your drill (these are available at harbor freight for around $20. These are one of the best tool investments I have ever run across). Start from one side of the panel and slowly widen the hole to 3/4" . They flip the panel over and widen the opposite side to 3/4". (since this is a tapered drill bit you can not drill straight through!!)
    Now assemble the locking mechanism according to the instructions. Make sure that your key alignment and locking tab are correctly oriented. Use loctite at this point to insure everything stays secure. Once you have verified everything works its time for the last step...
    The last step is nothing more than taking your adjustable pliers and bending the lock bar for a more secure fit.
    Obviously this is not going to stop anyone from getting inside of your storage bins but its a good way to make them move on to the next vehicle.
    I hope this helps out...
    Enjoy :)
  2. Jun 30, 2010 at 4:36 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Great idea! Thanks
  3. Jun 30, 2010 at 4:38 PM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    Great idea. Rep for you!
  4. Jun 30, 2010 at 4:38 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Great write-up!
  5. Jun 30, 2010 at 4:52 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    sweet write up
  6. Jun 30, 2010 at 5:49 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Nicely done, easy, cheap and a good description. Thanks for the idea.
  7. Jun 30, 2010 at 5:54 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    :popcorn: for later use
  8. Jun 30, 2010 at 5:56 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I've been thinking about doing this for a while now. I just don't feel comfortable leaving anything in those compartments right now.
  9. Jun 30, 2010 at 5:57 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Nice write-up... subbed for a slow weekend when I have time for a quick project.
  10. Jun 30, 2010 at 6:08 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  11. Jun 30, 2010 at 6:14 PM
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    good stuff, FYI, long beds that don't have the power outlet will require 4 locks, my access cab has the same size compartments on both sides of the bed, each with 2 locks
  12. Jun 30, 2010 at 6:15 PM
    mgage10
    mgage10 Well-Known Member
    Salt Lake City, UT
    2010 White Tacoma TRD Sport Long Bed 4x4
    Bilstein 5100s with Add-A-Leaf 18x9 XD Addicts on 285/65R18 Nitto Terra Grapplers G2 TRD Skid Plate Gray Husky Liners Venture Shield Clear Bra TRD Sport Pedals Seat Belt Alarm Disabled LED Map Lights (Cool White) LED Dome Light (Cool White) LED License Plate Lights (Cool White) White Engine Cover White Toyota FJ Grill Badge Viper 2 Way Alarm System Debadged Tailgate Fog Light Anytime Mod Window Tint Black Mesh Upper Grillcraft Black Mesh Lower Grillcraft Black Mesh Grillcraft Triangles Raven Speed Antenna AFE Stage 2 Pro-Dry S Intake Doug Thorley Long Tube Headers
    Beautiful. I've been wanting to do this for a while but wasn't exactly sure how. Looks great!
  13. Jun 30, 2010 at 7:50 PM
    chaztoyo
    chaztoyo Well-Known Member
    Chaz
    West TN
    10 Tacoma DCSB TRD Sport White
    Great idea, and you did a great job on the write up and pics.
    Thanks.
  14. Jun 30, 2010 at 8:43 PM
    tiresmokintacoma
    tiresmokintacoma Bean&Cheese Taco
    VIC
    Texas
    18 DCLB OR Prior: 99LX470/05DCOR97LX450/914R
    Basic
    Just added this 2 my favorites. Great idea!!
  15. Jun 30, 2010 at 8:47 PM
    RMTacoguy30
    RMTacoguy30 Well-Known Member
    Jay
    Murrells Inlet, SC
    10 DC Prerunner Sport TRD
    EGR in channel Vent Visors, Flowmaster American Thunder Dual Exhaust, Thule ToolBox, AFE Pro Dry Drop In Air Filter, Weathertech Floorliners, TC UCA's, Camburg Spindles, AllPro 3" rear.
    Sweet. I was looking at mine today and thinking about how to add locks.. Saved me some time.
  16. Jun 30, 2010 at 8:48 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    same
  17. Jun 30, 2010 at 11:30 PM
    tackyfinger
    tackyfinger Member
    SoCal
    10 TRD Sports DcSb. M gray.
    nice, thanks
  18. Jun 30, 2010 at 11:46 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Awesome... I'm going to do it just because the stock latches suck haha.
  19. Jul 1, 2010 at 8:45 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Subbed this is awesome......rep
  20. Jul 1, 2010 at 8:50 AM
    bearing01
    bearing01 Member
    San Diego
    4x4 TRD V6 MT
    great write-up
