Bed - Thule Rack & Access Cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NLF, Jan 4, 2011.
  1. Jan 4, 2011 at 7:04 AM
    NLF
    NLF [OP] Well-Known Member
    Levi
    Minneapolis, MN
    '11 TRD Sport DC LB 4x4
    OME 884 & Bilstein 5100s @ 0, TSB Rear w/5100s, 20x8 Mamba M2 275/55/20 Geolander, Access Cover
    I have a Thule rack system off of my Leer topper that was on my 09 DC. I just switched to the 11 DC LB and want to run an Access cover instead of topper. I would like to mount the Thule racks on the bed to haul bikes above my access cover. Has anyone done this? Would I make a special bracket or could the brackets simply bolt into the bed (not real excited about drilling into my new bed). Thanks for any ideas.
  2. Jan 4, 2011 at 9:36 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  3. Jan 4, 2011 at 9:46 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'm not sure if this will help but here is my setup.
  4. Jan 4, 2011 at 10:04 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I plan on doing the same thing.
    The suggestions above wouldn't allow you to close the tonneau cover.
    From my research, It looks like you can either permanently mount landing pads (I can't remember the # but they are the ones you would use for camper shells) to the bed side caps and attach towers and crossbars to that. Or you can add a rail system to the caps (a bit more expensive obviously) which would allow you to move the towers if needed. Both options would require drilling the bed caps.
    Do you still have the rack from your topper?
  5. Jan 4, 2011 at 11:38 AM
    NLF
    Levi
    Minneapolis, MN
    Yes, I took rack with mounts, just left the tracks. I just hate to drill into the bed. At this point, I am running out of options.
    Thanks for the other posts, but i have searched all the forum and can't find anyone that has ran one on the bed caps to be able to utilize the access cover.
  6. Jan 4, 2011 at 12:28 PM
    NLF
    Levi
    Minneapolis, MN
    So if I drill the bed cap, will I have to worry about rust? Is it all composite or some metal to worry about?
  7. Jan 4, 2011 at 12:36 PM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    There was a guy from Vermont snakeii who did this using the channels on his 05 bed rails. If you want pics here is the thread (it was before my days on TW). I do not know if he is a member here.
    His cover was a retrax instead of access but the pics will give you an idea
    Here is the thread, not sure if you can see the pics without signing up.
    http://www.tundrasolutions.com/foru...86170-retrax-tonneau-meets-yakima-track-rack/
    I attached a couple from his thread...again this is snakeii's setup.
  8. Jan 4, 2011 at 12:49 PM
    macgyver
    Brad
    Canton, GA
    BINGO! Pics are tiny though. The larger versions can be viewed in the link above without logging in.
