Bed tie down points
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Diabl0, Aug 12, 2022.
  1. Aug 12, 2022 at 3:22 PM
    Diabl0
    Diabl0 [OP] 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    I’m picking some 8’ 2x4’s on Sunday, any advice for securing them in the bed? I need about 30 of them to build a shed. I have a short bed by the way. Can I haul 30 in one trip?
    I need to get some more tie down points for the back bed. Which should I order?
  2. Aug 12, 2022 at 3:52 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    On average each of those 2x4’s is 11 lbs, or 17 lbs if pressure treated. That range is 300-500 lbs for the 30. You are good on the bed weight capacity, if you have no other weight to account for. The tail gate capacity is, I believe, 300 lbs. You are good there also, given it will see about half the weight, at most. Your bed is about five feet long, plus a foot and a half for the tailgate. If the tailgate hangs a little low, put a 2x4 across it to help hold the weight, else the 2x4’s may tip over. Dont forget a red flag. It’s the law in some jurisdictions.
  3. Aug 12, 2022 at 3:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t see why you couldn’t.
    I usually strap them in a bundle with ratchet straps. Then strap the bundle to bed anchors on the bed floor.
    Geeves77 and ImMrCrash like this.
  4. Aug 12, 2022 at 4:09 PM
    Diabl0
    Tim
    Massachusetts
    Thank you. I know I have 2 bed anchors near the tailgate but what about near the cab. How do I secure that area without anchors?
  5. Aug 12, 2022 at 4:16 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    I read this title waaaay too fast, that or i need to get out more. My mind went to the bed you sleep in. Sorry, nothing of value to add.
  6. Aug 12, 2022 at 4:17 PM
    TnShooter
    Deogee
    STOCK
    It’s hard to explain with our pictures.
    But I use one strap around lumber. Then use another strap to hook on to the strap around the lumber and back to the bed cleats on the rail.
    To be honest. All you need to do is make sure the lumber doesn’t slide out of the bed. Sometimes I don’t even tie off at the cab. I just tie at the back points.
    Just use your judgment, you’ll be fine.
  7. Aug 12, 2022 at 4:22 PM
    Diabl0
    Tim
    Massachusetts
    Sounds good I know my straps. Thanks for the tips
    TnShooter[QUOTED] likes this.
