Bed tie downs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Og Neon, Dec 27, 2008.
  1. Dec 27, 2008 at 6:18 PM
    Og Neon
    Og Neon [OP] Member
    Wichita
    TRD Off Road
    I picked up a 03 Ext Cab v6 Taco. But the previous owner removed the tie down anchors in the corners. I tried looking in a junk yard and there wasn't a single taco to be found (good and bad). Any ideas where i can get some replacment ones? I have to move in a couple of months and need something to anchor my bike down to. Any help would be great. Thanks
    MattMan01 likes this.
  2. Dec 27, 2008 at 6:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check this link out....look thru it,as you may be able to find exactly what you are looking for. hope it helps man!
    http://trdparts4u.com/
  3. Dec 27, 2008 at 7:11 PM
    Og Neon
    Og Neon [OP] Member
    Wichita
    TRD Off Road
    appreciate it man. I will give it a shot. Thanks
  4. Mar 14, 2010 at 7:21 AM
    PGHTACO
    PGHTACO New Member
    PGH, PA
    2002 Ext Cab vs TRD
    I have an 02 Ext Cab same issue need replacement anchors. No luck at that site any ideas. I have one anchor with screws and was considering sending it to Purelycustom.com the can make this kind of stuff.
  5. Mar 14, 2010 at 7:27 AM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    the d rings for the bed are right on the front page of trdparts4u
  6. Mar 16, 2010 at 7:01 PM
    PGHTACO
    PGHTACO New Member
    PGH, PA
    2002 Ext Cab vs TRD
    The 2001-2004 Tacoma has anchors that are in the corners at the seam of the 4 corners with two screws each. Spoke to my local Taco dealership parts dept today what we are looking for is: Rope Hook Assembly Part no# 66312-35010 $9.66 each and the Screws par no# 90149-80034 $.70 cents each.
    Cheers
    joe25rs and keakar like this.
  7. Feb 10, 2011 at 4:10 PM
    Og Neon
    Og Neon [OP] Member
    Wichita
    TRD Off Road
    PGHTACO...i did not see your response but thanks alot for the help! That is what I was looking for.
    James
  8. Feb 10, 2011 at 4:23 PM
    tacomabud
    tacomabud Well-Known Member
    Bud
    RI
    04 Black Xtra Cab
    K&N replacement, 4" Deck plate mod, Thrush Welded muffler, 2nd Gen. TRD rims, Herculinered bed, Grey wire mod, OME lift w/ 883 coils and AAL, 265/75/16 BFG A/T, AP 1.5" wheel spacers
  9. Feb 27, 2011 at 7:42 PM
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    Anyone know what size these bolts are? I'd prefer running out to the local hardware store then paying an extra 9 bucks for shipping
  10. Feb 27, 2011 at 11:15 PM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    K&N high flow filter, 2x Yakima bike mounts
    oooh haha I have all 4 still, but I wanted to add 4 more in the lower portion so I found p/n for the ring and bolts...
    here ya go...oh and btw I suggest toyotapartszone.com they seems to have the most reasonable prices and I know this forum trusts them...
    rings: 66312-35010 [order 4 (1 per corner)]
    bolts: 90149-80034 [order 8 (2 per ring)]
  11. Sep 1, 2015 at 7:07 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    Another 1st gen owner here looking at tie down ideas. I resurrected this old thread partly to ask how the OEM rings' bolts are secured. Is there a stationary nut built into the bed for them, or a regular nut you can access somehow? I have my 4 top rings but like subtle shift mentioned above, am interested in adding 4 more at the bottom corners.
    I'm also looking at some of the VersaTie track systems from Mac, http://www.macscustomtiedowns.com/category/VersaTieTrackKits, also their Anchor Plates, http://www.macscustomtiedowns.com/category/AnchorPlates and what seems to be a similar track setup from USA Cargo Control, http://www.uscargocontrol.com/Ratchet-Straps-Tie-Downs/Airline-Straps-Hardware
    The benefits to track appear to be freedom from having to use different length strap and the ability to place secondary things in different spots in the bed, that is to say, tie down stuff individually. Because if you only have (let's say) 2 or 3 anchor points per side, now you're essentially tying all your gear together.
    Not sure which way I'll go just yet.
    The other curiosity is all the factory holes, facing inward in the bed rails every few inches. "Modern" bungees have plastic ends too big to fit in those. I suppose I could bolt a few D-rings in.
  12. Sep 2, 2015 at 4:55 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    I went with the US cargo stuff.
    I have the aircraft version in 4' lengths and have 6 Double D retainers.
    Good quality product.
  13. Sep 2, 2015 at 4:59 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yes, uscargocontrol.com is a pretty good site for all things tie down related!! Pretty much anything you could think of! I really like those adjustable L-track tie down rails. Quite versatile I think.
  14. Sep 2, 2015 at 5:19 AM
    deckeda
    Interesting ... I didn't see 4' lengths on their site, or kits like Mac's has. Maybe I'll contact them.
    Hey, do you have a picture of your install?
    Also, the site says the track holes are about every 4 inches. Did you measure or just eyeball it to avoid drilling into a crossmember below or whatever? (I'd read that elsewhere but it might have applied only to standard beds, not our short ones?) Thanks.
  15. Sep 2, 2015 at 5:51 AM
    Ritchie
    Here you go. Phone pic and its still dark:
  16. Sep 2, 2015 at 5:57 AM
    deckeda
    Awesome, thank you.
  17. Sep 2, 2015 at 6:00 AM
    Ritchie
    Are you installing into a short or long bed?
  18. Sep 2, 2015 at 6:06 AM
    deckeda
    '04 Double Cab PreRunner SR5, so it's short bed.
    That 4' length looks perfect.
  19. Sep 2, 2015 at 6:09 AM
    Ritchie
    Before you do any drilling, I'll get you some measurements.
    I ran into a couple snags due to the one of the cross members... gotta wait for the sun to come up.
    I'll get some better pics too.
  20. Sep 2, 2015 at 6:19 AM
    deckeda
    I appreciate it. But there's NO rush; I'm a good week away from buying anything.
