bed tie downs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by michigantacoowner, Jul 27, 2007.
  1. Sep 5, 2007 at 8:35 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Nah man your not going crazy, here is a pic of my old D-Cab with my bike in the back.
  2. Sep 5, 2007 at 8:40 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I am glad that I am not the only one that built a ramp using the 2x6 kit from Sears/Autozone. I used that for years and then sold it with my last bike. Nice looking DC, BTW. :)
  3. Sep 5, 2007 at 9:27 AM
    stratton
    stratton Well-Known Member
    thats what i meant by my ? before. i think i am going to do the same thing.
  4. Sep 5, 2007 at 9:46 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    I think (since you have the short bed) that will work out to be the best option for you.
  5. Sep 5, 2007 at 11:08 AM
    Burns
    17 DCSB Off-Road
    Yep but unfortunately I no longer own all three. :mad: Traded the truck in last September for my X-Runner, The bike and the 2 x10 ramps I sold in July.
  6. Sep 5, 2007 at 11:09 AM
    Burns
    17 DCSB Off-Road
    I have other pics of my setup on my old truck shoot me a pm if you want to see more. I dont wanna clog up TCBOB's awesome site with pic's of a truck I no longer own. :D
  7. Sep 5, 2007 at 12:23 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Thanks for the compliment, I am here to help. :D
    Mark,
    You're welcome, you are right it is pretty straightforward, and it is absolutely necessary to have something lower than the rail system. Toyota should have put them in from the factory. Just make sure to get your wife or someone to come out and hold the plates square while you tighten the bolts, or take LRH's advice and use the 3m spray adhesive. I doubt that you will, but should you run into any problems or need a clearer picture of something let me know.
    This is probably a correct statement, though an Ultra Classic, or simmilarly heavy bike would likely cause the failure of the un-reinforced tailgates mentioned in other threads. Also, the only reason that I advised against using this system for heavy bikes is that I am overly cautious with my bike, and even in the trailer, I have a ratchet strap at all 4 corners, plus a set of cam-lock straps at all four corners as well. In the un-likely event that any strap should fail then I still have a back-up. I also check the straps every time I stop for fuel or lunch when I am trailering my bike as well. Call me paranoid, but I suspect it is because I have more money tied up in custom paint on the bike, than it cost when it was new.
  8. Sep 12, 2007 at 7:05 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Is the bolt in the bed a torx? If so, what size? I plan to add a couple D-rings this weekend.
  9. Sep 12, 2007 at 7:29 PM
    wrxed96
    wrxed96 Well-Known Member
    I think I am learning to trust the bed rails. I have had my GSXR 750 in there for a 1k trip with no issues. I thought I needed to add some tie downs, turns out those engineers know what they are doing. Who would have thought.
  10. Sep 13, 2007 at 3:23 AM
    stratton
    just dont trust the roof racks to much. i put my canoe up there this last weekend. and the front one pretty much kinked. it looked like it was going to snap off if i went over a bump. I had to cut down a 2x4 and rest the canoe on top of that.
  11. Sep 13, 2007 at 6:25 AM
    Burns
    17 DCSB Off-Road
    If my memory servers me correctly the bed bolts are t-55 and the d-rings in the back of the bed are t-45's. I got my torxs from sears.
  12. Sep 19, 2007 at 6:02 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    I installed an extra set of d-rings in the front of the bed today. Thanks Homer - the bed bolts are in fact T-55. One of the bed bolts came out very easily. The other one was a real pain in the A.
  13. Sep 19, 2007 at 6:26 PM
    stratton
    hey where did you get those bolts. and do they swivel?
  14. Sep 19, 2007 at 7:15 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    You can order an extra set of d-rings from Toyota. They come with a metal backing plate to install them through the plastic bed. However some of us simply install them under the existing bolts in the bed that hold the bed to the frame. This way they are about as strong as you can get. The down side to doing it this way is that they do not swivel. To me that is no big deal.
  15. Sep 19, 2007 at 7:19 PM
    #35
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    Just to be clear...if you mount them as they come, with the metal backing plate they do swivel just like the ones that come in the back of the bed. They look identical. I can post pictures if you want. I believe there are pictures on the site already if you look hard enough...
  16. Sep 20, 2007 at 6:08 AM
    #36
    Burns
    17 DCSB Off-Road
    NO problem man that what this place is all about, helping each other out.:D
  17. Jan 14, 2008 at 8:13 AM
    #37
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I pulled out the bed bolts for mine too. Nothing less than an impact wrench and torx bit for the wrench would get them out. But at least I know those suckers aren't going anywhere! :laugh:
    th_DSCF0738_842a8e5375ae004d9329330b5a069de41a54c4d7.jpgth_DSCF0741_c7b8cf6907edcefa41d34a29405198d4dfe940d3.jpgth_DSCF0742_99683ebff939d7e0556c87bb48daf37c6c6cf771.jpg
    Ranger 1/75 likes this.
  18. Jan 14, 2008 at 7:23 PM
    #38
    budisit
    budisit Active Member
    Buddy
    white, long bed, TRD, dbl cab
    Why won't the D-rings swivel when using the bed mounting bolts ? Could the D-ring attachment hole be drilled out larger in order to get the swivel back on ??
  19. Jan 14, 2008 at 7:33 PM
    #39
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    if you look back up at 007tacoma's pictures, you can see that on both sides right on top of the wheel wells, there is a little recessed area. i assume that is where a toolbox would rest if you got one. as i do not plan to get one, they make a great mounting area...they are very easy to reach when installing, they are protected because of their lowered position , and you can tie down quite a load with that angle.
  20. Jan 14, 2008 at 8:34 PM
    #40
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Is it me?...Or does your rear left tire lean out 2wards the top?...Or is it a slanted driveway with the weight of your bike that does that?
