Bed topper carpet shedding
Discussion in 'General Tacoma Talk' started by mike759, Apr 27, 2025.
  1. Apr 27, 2025 at 3:24 PM
    mike759
    mike759 [OP] Well-Known Member
    Colorado
    2002 Xtra cab TRD off-road
    2.5" lift, JBA UCA, OME rear leafs, 33s...
    I recently picked up a fiberglass topper with a carpeted interior. Every time I touch the carpet, a thick dust cloud falls. At first, I thought it was just very dusty, but now I'm realizing it's the carpet itself shedding. Does anyone have experience with some kind of adhesive to spray over it to prevent it from shedding further? I'm open to any and all suggestions, as I plan on camping out of it soon and don't want to breathe it in while I sleep.
  2. Apr 27, 2025 at 4:30 PM
    mike759
    Colorado
    Update: I got impatient and sprayed 3M 77 adhesive all over it. Will report back when it dries
  3. Apr 27, 2025 at 5:21 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    more than likely, you'll be best off scraping and re-covering it starting at the raw topper fiberglass. the dust is most likely the adhesive failing
    mike759[OP] likes this.
  4. Apr 27, 2025 at 5:29 PM
    mike759
    Colorado
    Do you mean the adhesive holding the carpet to the fiberglass? I figured I'd probably have to rip it out, but might as well give something a try first.
  5. Apr 27, 2025 at 5:32 PM
    yotadust
    yotadust Well-Known Member
    lol is it dry yet. can you put some pics?
  6. Apr 27, 2025 at 5:40 PM
    soundman98
    NW Indiana
    if it's coming off from the carpet, it's likely not the carpet-to-fiberglass, but the carpet-to-carpet layer failing. really depends on the type of carpet they used. there's blown-on, and there's sheets. i've seen normal carpet bonding sheets fail in houses and cause plenty of dust.
  7. Apr 27, 2025 at 7:28 PM
    mike759
    Colorado
    It dried and it helped a little, perhaps another coat will help further.
    I'm now realizing I'll probably cut it all out and paint the fiberglass. Not sure I want to enclose myself in there with whatever material is raining down.
    soundman98[QUOTED] likes this.
  8. Apr 29, 2025 at 12:47 PM
    mike759
    Colorado
    Following up on this, has anyone ever pulled a carpet out of one of these? If so how bad of a process is it? I assume I’ll need to wear a mask. Should the fiberglass be sanded or can I just go at it with a thick layer of paint?
  9. Apr 29, 2025 at 2:31 PM
    wfxt
    wfxt Well-Known Member
    The Empire State
    2025 Underground THLB (2021 MGM T4R Pro)
    I would wear an N-95 respirator. Those particles are small.
