Bed wear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Newfiebruh, Aug 26, 2019.
  1. Aug 27, 2019 at 2:27 PM
    Newfiebruh
    Newfiebruh [OP] Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    Interesting, what do you recommend to do with the tape?
  2. Aug 27, 2019 at 2:32 PM
    tacotrucktrd15
    tacotrucktrd15 That's a positive on the negative.
    ORD
    MMXV MGM TRD Sport 4x4
    Cover the area that is worn out so it doesn’t wear any more. It is a temporary repair but some people are not comfortable using fiberglass and metal or performing repairs that involve cutting into the wheel wells or the bed.
  3. Aug 27, 2019 at 5:05 PM
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
  4. Aug 28, 2019 at 6:39 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Only sticks to surfaces when baked in, like any other surface coating. The spray bottles that claim to have it are BS.
  5. Aug 28, 2019 at 6:40 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  6. Aug 28, 2019 at 6:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Bedliner, tape, epoxy, etc. will do nothing for that in terms of strength, especially if under use.
    Fiberglass is the best repair, but will have the same problem when you abuse it again.
    1) Easiest option is to not haul stuff that rubs the wells. Or get a trailer.
    2) would be to glass it up inside and out, then Monstaliner the whole bed (if you want a consistent look) or the wells if that's good enough for you. Then make formed aluminum caps to fit over the corners and down the top ridge of the well. Rivet them into your newly reinforced well. It doesn't need to be super thick, just durable.
    3) most complex, but most permenant solution if you intend to continue big hauls
    To add to this, if you could cut out a wheel well from a wrecked truck in the yard, you could downsize it and mount it from the underside of your well as a base with a good shape to work with.
  7. Aug 28, 2019 at 9:58 AM
    Turdyota3000
    Round da corner
    I’m not talking about spray Teflon, I’m talking about Teflon block/sheet..
  8. Aug 28, 2019 at 11:06 PM
    Tacomataco12
    Tacomataco12 Well-Known Member
  9. Aug 28, 2019 at 11:16 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Ya, some people should have their man cards confiscated. Given that his problem stems from slightly too little space I’d cut those areas out and reattach them 1” farther apart(1/2” each side). If the wheels are too close, space them farther out.
  10. Aug 28, 2019 at 11:21 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Are you loading old sleds with metal skis? None of mine with plastic skis did that and on my old 94 Arctic Cat I replaced the original metal skis with plastic ones for under $150 if I remember right.
    bagleboy likes this.
  11. Aug 29, 2019 at 9:41 AM
    Newfiebruh
    Tom
    nope, plastic skis
