Bed Weight Suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Anchovy, Mar 30, 2018.
  1. Mar 30, 2018 at 12:19 PM
    Anchovy
    Anchovy [OP] Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I've been looking for some weight to add in my bed but I don't want it to be sandbags or cynderblocks or things like that. I seen the shurtrax stuff but have wildly varying reviews. Any suggestions?
  2. Mar 30, 2018 at 12:34 PM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Why don't you want sandbags? Thats the cheap solution. If I were you i'd build a cheap wooden box to throw over the wheel wells and drop a few sandbags in there.
    ARCOVT16 and Hairy Taco like this.
  3. Mar 30, 2018 at 2:10 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Bed mat and a metal rear bumper.
  4. Mar 30, 2018 at 2:17 PM
    Tacos in Gensokyo
    Tacos in Gensokyo Bohemian Archive in Japanese Red
    2017 SR 4cyl MT SSM
    Rokblokz Mudflaps, 2015 TRD Pro Suspension
    Have a local shop plasma out a sheet of 3/8'' steel to fit the bed. :spending:
    WarrenG likes this.
  5. Mar 30, 2018 at 2:45 PM
    Anchovy
    TRD Ferguson
    Sandbags almost always rip open and just cause a huge mess. I also don't really want to deal with constructing anything since that's what I do for a living
  6. Mar 30, 2018 at 2:46 PM
    Anchovy
    TRD Ferguson
    I just have to go to my shop with a 3/8" sheet of metal, they'll use the plasma cutter lol
  7. Mar 30, 2018 at 2:47 PM
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    What about tractor weights?
  8. Mar 30, 2018 at 2:47 PM
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
    -high clearance rear swing out bumper
    -35" spare to match the other 4
    -10 gallons of gas
    -bed bars
    -RTT
    done.
  9. Mar 30, 2018 at 2:49 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Why do you want to add weight? Aside from snow traction, it will just add wear and tear as well as decrease MPG.
  10. Mar 30, 2018 at 2:50 PM
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
  11. Mar 30, 2018 at 2:51 PM
    ferntr33
    ferntr33 Well-Known Member
    Dual battery setup relocated to rear. Ad a second spare. Fuel cell. . .
    Curious why?
  12. Mar 30, 2018 at 2:53 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I thought that might happen, but the two that I used this winter were great until I dumped them out. I did rope them to the D rings so they didn't slide around.
  13. Mar 30, 2018 at 3:04 PM
    Anchovy
    TRD Ferguson
    The ride quality on any truck is much better if you have weight in the bed. My truck hydroplanes like a madman in the rain. Mpg isn't going to be changed much and wear and tear on the tires isn't going to be much because the tires get rotated regularly. Also the tires I have are an LT tire that are recommended at 80 psi
  14. Mar 30, 2018 at 3:06 PM
    Anchovy
    TRD Ferguson
    The shurtrax things add 300-400 lbs in the bed and can handle 500 on top of them. They just have very mixed reviews, some say they only last one or two freeze cycles other say they've lasted for years
  15. Mar 30, 2018 at 3:11 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    As was suggested, just build a nice container for the sandbags and some other things. That if the sandbag split open you don't end up with a mess. It also allows you to build something easily removable and not valuable.
    tonered likes this.
  16. Mar 30, 2018 at 3:12 PM
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    Water expands when it freezes. I don't know that I'd trust a bag full of it to last very long in winter. Steel doesn't have that problem. You can get alot of weight back there for not much real estate lost. If you have access to a decent plasma cutter, I'd just have some plates cut. We have some kicking about the shop right now, 3 1/2'' 24x24''. They weight like 200 lbs apiece. Or tractor weights, 4 one hundred pound weights in back would do it.
  17. Mar 30, 2018 at 3:15 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    What kind of tire are you running I have never run anything close to 80 psi. Especially in a mid sized truck with no weight in the back or pulling a trailer.
    Just because it says max psi 80 on the tire doesn’t mean that’s what your supposed to run it at
    edgerat likes this.
  18. Mar 30, 2018 at 3:16 PM
    Anchovy
    TRD Ferguson
    They're Cooper discoverers, I'm not running them at 80 psi but that's what they're rated for, says on the side of the tire.
  19. Mar 30, 2018 at 3:18 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Ok. I got you. :thumbsup::thumbsup:
  20. Mar 30, 2018 at 3:22 PM
    WarrenG
    WarrenG Well-Known Member
    This is the best answer. Buy 1/4” 4x8 (320lb) and you could zip cut to fit. Takes up the least amount of space.
    Edit- never mind you have acess to plasma, easy.
