Bed width
Discussion in '1st Gen. Tacomas (1995-2004)' started by dud122, May 31, 2019.
  1. May 31, 2019 at 4:47 AM
    dud122
    dud122 [OP] rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    Could someone with either no bedliner or a spray on liner (not drop in) tell me what the exact distance is of floor space between the wheel wells?
    Thank you!
    BLACK04TRD likes this.
  2. May 31, 2019 at 5:26 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Per Wikipedia it's 40".
    First generation (N140/N150/N160/N170/N190)
    Overview
    Production
    January 1995 — August 2004
    Model years 1995—2004
    Designer Kevin Hunter (1991, 1992)[1]
    Yusuke Fukushima (second facelift: 1998)
    Body and chassis
    Related
    Powertrain
    Engine
    Transmission
    Dimensions
    Wheelbase
    • 1995-2000 Regular Cab: 103.3 in (2,624 mm)
    • 2001-04 Regular Cab: 104.3 in (2,649 mm)
    • Xtracab: 121.9 in (3,096 mm)
    Length
    • 1995-97 Regular Cab 2WD: 174.8 in (4,440 mm)
    • Xtracab 2WD: 193.3 in (4,910 mm)
    • 1995-97 Regular Cab 4WD: 180.5 in (4,585 mm)
    • 1995-97 Xtracab 4WD: 199.0 in (5,055 mm)
    • 1998-2000 Regular Cab 4WD, 1998-2002 PreRunner Regular Cab 2WD: 183.8 in (4,669 mm)
    • 1998-2002 Xtracab 4WD & PreRunner Xtracab: 202.3 in (5,138 mm)
    • 1998-2002 Regular Cab 2WD: 184.5 in (4,686 mm)
    • 1998-2002 Xtracab 2WD: 203.1 in (5,159 mm)
    • 2003-04 Regular Cab 4WD: 184.4 in (4,684 mm)
    • 2003-04 Xtracab V6 & Double Cab: 202.9 in (5,154 mm)
    Width
    • 66.5 in (1,689 mm)
    • Between wheel well: 40 in (1,016 mm)
    • 2001-02 Crew Cab: 70.1 in (1,781 mm)
    • 2003-04 Crew Cab: 70.3 in (1,786 mm)
    Height
    • 2WD: 61.0-64.1 in (1549-1628 mm)
    • 4WD: 66.3-67.7 in (1684-1720 mm)
    Curb weight
    • 2WD: 3155 lbs
    • 4WD: 3877 lbs
  3. May 31, 2019 at 5:28 AM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    Thank you!
  4. May 31, 2019 at 6:11 AM
    Wsidr1
    Indiana
    @BartMaster1234 didn't you post a brochure image once that had 1st gen bed dimensions. I searched and saw it referenced in Lunchtable, but never found the image.
    @dud122
    Tyler lives in California so he may not answer for a few hours.
    dud122[OP] likes this.
  5. May 31, 2019 at 7:15 AM
    BLACK04TRD
    BLACK04TRD Well-Known Member
    Bethesda, MD
    2004 Tacoma TRD, 3.4L, 5spd -- SOLD
    Stock AF
    @dud122 Great to see another Marylander on here!
  6. May 31, 2019 at 9:34 AM
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    I've been able to haul something 42" wide if it doesn't have to sit on the floor and can be set on some 2x4s to be a little elevated over the flared out bottom part of the wheel well.
  7. May 31, 2019 at 11:18 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I’ve been summoned?
    SamSpade and Wsidr1 like this.
  8. May 31, 2019 at 11:25 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    How wide is it between the insides of the fenders?
  9. May 31, 2019 at 2:46 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Because of the radiused wheelwell humps, it's tough to get a specific measurement. 40" easily, maybe 1/4"-1/2" more.
  10. Jun 1, 2019 at 2:27 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I load 40" pallets all the time with the bed liner in my 2000
