bedlight/add-a-circuit help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alexretama, Jul 5, 2011.
  1. Jul 5, 2011 at 1:03 PM
    alexretama
    alexretama [OP] Well-Known Member
    Alex
    Long Beach, CA
    05 prerunner
    HornBlasters Train Horn, Onboard Air System, 3" Spacer Lift, Black Plasti dipped emblems and fog light sleeves, Bed Pocket Lock Mod
    So I have 4 12" led strips all wired, mounted, and ready to rock along with a door jamb switch, so they come on when i let the tailgate down, and a kill switch in the bed pockets so I can turn them off when not in use. I got an Add-a-fuse but I'm not entirely sure which slot to put it in.
    Do any of the slots behind the coin tray run constant power even when the truck is off?
    I blew a 7.5amp fuse so should I amp it up to a 10amp fuse? (the package doesnt say how many amps each strip draws but I got the idea that the drew 1.5 amps each from oznium.com)
    I've made sure everything is grounded by running a ghetto wire straight to the battery with an AM fuse box so I know the leds work I just hate to run wires from battery the permanently because it look sloppy.
    Thanks for reading!
  2. Jul 5, 2011 at 5:33 PM
    JKD
    JKD Well-Known Member
    What size wire are you running?
  3. Jul 5, 2011 at 5:42 PM
    alexretama
    Alex
    Long Beach, CA
    05 prerunner
    18 guage
  4. Jul 5, 2011 at 5:47 PM
    shane100700
    shane100700 Look'n like a fool with your pants on the ground..
    Fort Dix, NJ (MT born and raised)
    08 Off Road, DC
    Kenwood 6140 w/nav/BlueTooth/backup cam/ Focal Components/ Alpine PDX-5/ JL 10", rear storage lock mod, tint, Snug Top xtra vision, OEM running boards, XD Spy 18x9, Nitto Terra Gripper AT's, AFE pro dry, Ultra Gauge
    I wouldnt use 18 guage as the primary wire for any long runs, and def not straight to the battery, even on a test basis.
    Obvioulsy other info out there but this is a good read and worth the time to look it over;
    http://www.tacomaworld.com/forum/technical-chat/103969-electronics-basics-reference.html
    EDIT-
    BTW- If you want to find a constant hot for an "add-a-fuse", just get under there with a test light. You can get one cheap and is essential to any automotive or electronics tool box.
  5. Jul 5, 2011 at 8:36 PM
    JKD
    I sure wouldn't fuse 18 gauge wire for more than 5 amps, but I'd be really surprised if your LED bars are actually drawing 5+ amps. What are the specs on your LED bars? (should be marked in watts or amps)
  6. Jul 5, 2011 at 9:04 PM
    alexretama
    Alex
    Long Beach, CA
    05 prerunner
    i couldnt find it for the longest time but just found it today.. they draw 0.5 amps each
  7. Jul 5, 2011 at 9:11 PM
    alexretama
    Alex
    Long Beach, CA
    05 prerunner
    ya test light was my next option but i just wanted to make sure i wasnt getting overconfident and doing something completely obviously wrong. Great link by the way!
  8. Jul 5, 2011 at 11:39 PM
    JKD
    Okay, that's a 2 amp draw total, there is no way you need more than the 5 amp fuse you already have on that circuit. If the fuse is blowing, there's something else going on -- a short circuit or a bad LED module are the two things I'd look for.
  9. Jul 5, 2011 at 11:41 PM
    JKD
    Skip the test light and go straight to a multimeter. You can get a perfectly useable one at Radio Shack for $20 or less.
  10. Jul 6, 2011 at 9:50 AM
    alexretama
    Alex
    Long Beach, CA
    05 prerunner
    i have a multimeter but the stupid terminals dont fit!.. anywho i got an old fuze with an indicator light that was activated so i can find a terminal that has constant power...
    Thank you, gentlemen!
  11. Jul 6, 2011 at 2:53 PM
    shane100700
    08 Off Road, DC
    Anytime! :cheers:
