bedlined fender flares
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Jun 14, 2011.
  1. Jun 14, 2011 at 1:05 PM
    danteisme
    danteisme [OP] Well-Known Member
    Vandergrift, PA
    06 DCSB Sport, 96 Integra GSR
    i'm getting ready to do this soon on my base model. is it as simple as scuffing the surface and using some adhesion promoter for my prep work? i dont plan on using primer, just bed line the surface with the adhesion promoter on it.
  2. Jun 14, 2011 at 1:38 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Just out of curiousity, why are you bedlining what I'm assuming to be are the black plastic fender flares? Or are they color matched and you're looking to black them out?
  3. Jun 14, 2011 at 1:54 PM
    Dutch'nComa13
    Dutch'nComa13 Well-Known Member
    Joshua
    Rich Creek VA
    08 TRD sport 4X4
    Black FJ steelies with 285/70/17 Michelin ATs, black tacoma steelies with 255/85/16 Dunlop Rover MT, Blacked out fender flares, Custom built RPM Offroad front bumper, weathertech digifit floor mats, Toyota Prado snorkel, secondary air filter removed, AFE pro dry replacement filter, seat belt mod, 3" lift (OME 885 with spacers front, all pro expo leafs rear), Home made custom rear high clearance bumper.
    I did this on my sport. Easy as pie. Tape them off, you don't want to scuff your paint... Sand your flares, I think I used 120 or something pretty rough. Sand them until all the clear coat is gone. A D/A or equivalent sander will be your best friend with this one. Clean them off with a rag. Then, I rolled on Hurculiner. After your done applying, peel of the tape. Let it dry then go wheelin :D!! Easy as that.
    As long as you sand them down good there is no need for adhesion promoter.
  4. Jun 14, 2011 at 2:42 PM
    danteisme
    Vandergrift, PA
    they are blacked out currently, but look terrible. plastic is faded, you can see lines all through them. i tried using back to black on them, didnt work. i like this option next.
  5. Jun 14, 2011 at 2:43 PM
    danteisme
    Vandergrift, PA
    just by looking at your pic in your avatar, yours were painted already right? mine is just the black abs plastic or whatever the base 4x4's come with. thats why i wasnt sure about the painting, since its just bare plastic there isnt an existing paintjob for the new stuff to "bite" into
  6. Jun 15, 2011 at 9:58 AM
    Pugga
    Massachusetts
    F-150 Mod
    This sounds a little weird but you can get them back to the original black color with a little heat. You have to be careful, but it works!
    http://www.youtube.com/watch?v=Y-utsG8u5h0
  7. Jun 15, 2011 at 10:33 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    303 aerospace, FTW
  8. Jun 15, 2011 at 10:37 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    You will probably only need to do some light sanding. Wipe down the flares, allow to dry, roll on 1st coat, allow to dry 1-2 hours, apply 2nd coat, allow to fully dry and cure and then you're done. I've found that the magic erasers do a good job on the black plastic fender flares as well.
