Bedliner for plate bumpers
Discussion in '1st Gen. Tacomas (1995-2004)' started by Seagull233, Jan 24, 2019.
  1. Jan 28, 2019 at 2:19 PM
    2BeersPlease
    2BeersPlease Well-Known Member
  2. Jan 28, 2019 at 2:21 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  3. Jan 28, 2019 at 2:25 PM
    2BeersPlease
    I like the amber color, and they provide some protection. The lights come with a clear set and a diffused set to make them more flood-like. I'd like to find a diffused amber lens.
    ThunderOne[QUOTED] likes this.
  4. Jan 29, 2019 at 7:22 AM
    Seagull233
    Seagull233 [OP] Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I wanted a set of small square yellow "fog" lights. I wound up using white ones and applying some of that yellow tail light repair tape. Three years, and still looks fine.
  5. Jan 29, 2019 at 7:23 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I forgot about that, I know Lamin-x make yellow film you can stick onto aux lights
  6. Jan 29, 2019 at 7:25 AM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Hey, thanks for all the replies to my inquiry. I have used the Rustoleum spray in the past, and it has held up well enough that I will use it again, and it is readily available locally. BTW Home Depot is way underpricing Walmart on this.
  7. Jan 29, 2019 at 7:40 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    2BeersPlease[QUOTED] likes this.
  8. Jan 29, 2019 at 7:42 AM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    I would wait till it’s fully dried before doing a color coat on it, as well, the color coat will start to make the Berliner not look as good, because your adding more paint to it. And if you decide to spray paint a color over the bed-liner, you’ll get quite a few drips and errors along with it. Not to mention if the bedliner is being used as it should, your top coat of paint will begin to peel in spots if it gets hit with something. If you decide to use a spray gun, you will not get as many errors, still thou, If I were you I would try to buy a can of rhino liner or some type of Bedliner, that is white, and then mix some paint in with it to change the color. By can I mean a paint can that can be sprayed on with a paint gun
  9. Jan 29, 2019 at 8:29 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    totally worth it, especially if you drive in areas with lots of traffic on the highways. People from the side can see your signal.
    RysiuM likes this.
  10. Jan 29, 2019 at 8:52 AM
    2BeersPlease
    I used these.
    otis24[QUOTED] likes this.
  11. Jan 29, 2019 at 9:15 AM
    otis24
    Mark
    California
    Thanks!
    It's something in the back of my head whenever I use my turn signal.
    Back on topic- regarding bed liner...I'm in the camp that bed liner will be a pain in the ass to touch up when I tear off a huge piece of it on a rock. Same goes for powder coat.
    How about POR15 with a top coat of something more UV stable?
  12. Jan 29, 2019 at 9:40 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    yep I got the same ones, just clear to match my clear lenses.
    otis24 likes this.
  13. Feb 7, 2019 at 9:39 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Any of you guys that used the Rustoleum bed spray on your armor, did you primer first or just spray it on the metal? I have a skid plate that I'm going to paint with this stuff this coming weekend.
  14. Feb 7, 2019 at 10:07 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm curious, how did you prep your bed before applying the liner?
    I sanded and cleaned mine with alcohol, per the instructions.
    I did my coating (hurculiner) maybe 6 or 7 years ago. It took maybe 5 years before I started noticing that the clearcoat was pealing off, starting at the edge of the liner. Seems like water was getting under the clearcoat where I sanded.
    I'm wondering what I could have done different. Maybe overlap the liner and the unsanded clearcoat by 1/4 or 1/2"? I just figured that would peal off anyway.
  15. Feb 7, 2019 at 11:37 AM
    #35
    boostedka
    James
    NM
    I prepped mine pretty much the same way. I think I sanded with 220 grit. I had another truck with I rolled with Herculiner. That one I used Xylene on it instead of Alcohol before applying it. I didn't have any issues like you're describing with it. I just had issues with it peeling easier than I thought it should when using the bed.
    After using both Herculiner and Raptor Liner, the Raptor seems way more durable and solid of a finish. It's essentially like a 2 part epoxy because you add a hardening agent to the liner material.
    jbrandt[QUOTED] likes this.
  16. Feb 7, 2019 at 2:26 PM
    #36
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Rustoleum, did my whole truck. Stuff is tough as nails and much cheaper than the other stuff out there.
  17. Feb 7, 2019 at 3:40 PM
    #37
    villlein
    villlein Well-Known Member
    Ham
    04 Tacoma
    SAS with dodge D60/D70, 36 iroks, 5.86's welded rear, Eaton lock, OBA, half back cage, rear mount radiator, etc...
    Herculiner -I used a wire wheel, then xylene, then ospho prep, and finally 2 coats of heculiner, and found I didn't mix the liner very well (needed to use a drill to blend it), so it looks really nice and smooth in some spots, and once I got to the bottom of the can it was extremely textured -roll on application. Adhesion was pretty good- wish I had gone for 3 coats.
    Removing bedliner is a PITA. I tend to be the kind of person that's always doing a welding modification, and paint is much easier for prep. I've watched somebody torch it before and the smoke was nasty, even cutting is annoying.
    For paint: I just stick to acetone wash, oshpo application, primer, then paint. I'm not particular about brands, I find the cheaper stuff works just as well with this process -3-5 coats holds ups to most trees and shrubs.
