Bedrug install question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cvsizemore, Jan 22, 2022.
  1. Jan 22, 2022 at 6:05 PM
    cvsizemore
    cvsizemore [OP] Well-Known Member
    Charleston, SC
    I just installed a bedrug and the section between the tailgate and bed seems to make it hard to close my tailgate. I assume the fabric pinches between the two when it's closed but wanted to make sure this is correct.
    Anyone have the same concern?
  2. Jan 22, 2022 at 6:11 PM
    Montana_Actual
    Montana_Actual ;)
    Pics? From what I've seen on others setups, yes? I don't think it really matters if it pinches between or goes outward when it's closed. Is it hard to close if it's outward?
  3. Jan 22, 2022 at 6:15 PM
    cvsizemore
    Charleston, SC
    I'll take some pics when I can but yes, closes fine with it outward but when the fabric pinches between them it just takes some extra force to close the tailgate. Just want to make sure I'm not damaging the tailgate in any way.
  4. Jan 22, 2022 at 6:18 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Pull the section up and out of the gap. The BedRug will conform to that position over time.
    Montana_Actual likes this.
  5. Jan 22, 2022 at 9:07 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I just close mine and seems to close fine even though it folds down.
