beef brisket recipe
Discussion in 'Food Talk' started by coffeesnob, Jul 10, 2012.
  1. Jul 10, 2012 at 3:50 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I need a good method for beef brisket on the smoker. :)
  2. Jul 10, 2012 at 3:58 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I've only done one, but I used my pork shoulder recipe/technique and it worked really well.
    1. Buy a brisket
    2. Buy a canned dry rub that doesn't have sugar as the first ingredient.
    3. Take it out of the package, rinse it in water well and then pat dry w/paper towels
    4. Slather on a thin layer of yellow mustard and liberally coat with the rub
    5. Smoke fat-side down at 225 - 250 for around 1 hr/lb
    6. Double-wrap in foil tightly then bake in an oven at 210 until the internal temp is 190 or so. This will take a few more hours probably.
    7. Take it out and let it rest for at least an hour.
    My first and only attempt:
  3. Jul 11, 2012 at 3:39 AM
    coffeesnob
    VA
    looks yummy
  4. Jul 11, 2012 at 3:46 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Pretty good lookin first try there..........
  5. Jul 11, 2012 at 6:15 PM
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    Polymer Head, why do you smoke it fat side down. I thought that you would want fat side up so that the fat would leak through the entire slab of brisket??
  6. Jul 11, 2012 at 6:17 PM
    toughtaco
    Oh sorry, that didnt sound all that good the way I worded it. I am really honestly wondering because I need to know if there is a difference when smoking. I know that grilling or baking you would do it fat side up.
  7. Jul 11, 2012 at 6:52 PM
    Polymerhead
    Missouri
    I used to smoke shoulders fat side up for that very reason. Then I realized one time that at 190 or so, the fat renders and disappears. The top surface of the meat is where the best, smokiest "bark" develops. If that's where your layer of fat sits, then you eventually cook it all away along with the bark. If you don't cook it that long, your bark is still on top of a layer of fat and it all sloughs off when you pull the meat.
    A second reason is that when you cook the fat layer down, it's another buffer between the heat source and the meat if you're using a vertical smoker. Sometimes mine will spike 50 degrees if a particularly large chunk of smokewood ignites, and I like that layer of fat there to keep the meat from drying out or even burning from too much direct heat. Low and slow is the goal.
    I know cooks who prefer it both ways, but fat side down is best in my opinion. If you're using a waterpan, drynss shouldn't be an issue, especially with pork. Fat placement may not matter as much with brisket, i dunno.
  8. Jul 11, 2012 at 6:57 PM
    subwayaz
    subwayaz Well-Known Member
    Tucson,Az
    2012 Accesscab; TRD
    Super Charger, Catback Exhaust,Side Wind Shades, & Carbon Fiber Dash Kit
    That Brisket is looking really good;)
  9. Jul 11, 2012 at 6:57 PM
    toughtaco
    Perfect explanation, thanks. I didnt even think of the layer of protection between flame and meat. Thanks for the info..... I will definitely remember that one.
  10. Jul 11, 2012 at 7:04 PM
    Polymerhead
    Missouri
    No problem!
  11. Jul 11, 2012 at 7:04 PM
    toughtaco
    How hot and how long did you smoke your brisket????? I am thinking about doing a big one.
  12. Jul 11, 2012 at 7:05 PM
    toughtaco
    Sorry we are thread jacking a bit...
  13. Jul 11, 2012 at 7:06 PM
    toughtaco
    I just saw 200 the 225 and an hour a pound. So a bigger then 10 pounder would be more the 10 hours.... hmm ... maybe not that big then... I dont know yet.
  14. Jul 11, 2012 at 7:11 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I'll have to call my dad in the morning and get our recipe. Here's a pic.
    Or two.
    Pre-Cooking.
  15. Jul 11, 2012 at 7:14 PM
    toughtaco
    Those sandwiches look good. I am hungry now....
  16. Jul 11, 2012 at 7:19 PM
    Warhorseforever
    Will
    Sand Lapper
    As am I. I just got out the gym and just thinking about that soft, warm, pink, buttery, grass fed, juicy, succulent inside and burnt, crispy, flavorful outside goodness has me drooling right now. :goingcrazy:
  17. Jul 11, 2012 at 7:21 PM
    Polymerhead
    Missouri
    Warhorse, those look amazing!
    Tough - my wood smoker stabilizes between 225 and 250. Works great for shoulders and seems to work for brisket as well. An hour per lb is a good guide but a digital meat thermometer is your best friend.
  18. Jul 11, 2012 at 7:24 PM
    toughtaco
    As I said earlier in the foodies thread I was thinking about getting the digital meat thermometer and the aim at thermometer so that I can aim it at the grill where the meat is to figure out the temp nearest the meat.
  19. Jul 12, 2012 at 3:36 AM
    coffeesnob
    VA
    quite all right I'm all ears...
  20. Jul 12, 2012 at 5:33 AM
    toughtaco
    Well smoking brisket is going to be my next project on the smoker. So I am all ears as well
