Beefed carrier bearing drop bracket for lifted trucks
Discussion in 'Suspension' started by Beefed Taco, Sep 20, 2009.
  1. Sep 20, 2009 at 10:59 AM
    Beefed Taco
    Beefed Taco [OP] Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    My friend has a new Tundra that he had lifted at 4WP. They did the usual washer spacers to bring the carrier bearing down, but it was super cheesie. The bolts were long, there were 3 thick washers per side, for a total of 1" of drop and had a ton of flex & unwanted movement and he had driveline vibration. I made him this custom bracket, and made a top piece that gave it a 3rd attachment point using a factory hole in the crossmember above, which really Beefed it up by getting rid of the movement, and brought the C/B down a total of 2-3/4" for the proper driveline angles. Just thought I'd share. All vibrations went bye bye. waytogo_82a2dcfcbf91b28330a7f12007d2d5959649daa3.gif
    front shot
    [​IMG][​IMG]
    rear shot
  2. Sep 20, 2009 at 11:02 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Good work man. Was it difficult to install?
  3. Sep 20, 2009 at 7:23 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    This is the Truck.
  4. Oct 5, 2009 at 1:53 PM
    Zac
    Zac Member
    Zac
    tucson
    00 Tacoma SR5 4X4
    3-4 inch lift
    what does this provide you with less movement in the shaft?
  5. Nov 23, 2009 at 11:53 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Yes, that's what the 3rd attachment point above does, it uses a factory hole in the crossmember, since I noticed a ton of play in the stock flimsy brackets. This bracket is 1-3/4" longer than the 1" washers that lift installers use (for a total of 2-3/4")and puts the driveshaft where it needs to be if lifted above 3". I'm building one for a guy in Canada with a Tundra and for a guy with a 05+ Taco.
  6. Nov 23, 2009 at 3:37 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Would this be of any benefit to an 05 prerunner with rear lifted 1.5? from a longevity/sturdiness aspect?
  7. Nov 23, 2009 at 3:41 PM
    Brunes
    Brunes abides.
    Rotorhead
    Nice work Beefer!!
    T@co...Are you having vibes or anything?? If you aren't having issues the saying "Don't try to fix wat ain't broke" comes to mind....
  8. Nov 23, 2009 at 3:50 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    No vibes but just thinking the straighter the driveshaft line is, the longer the ujoints/ carrier bearing might last. Hear ya on the just leave it alone tho. Mostly curious..........
  9. Nov 23, 2009 at 3:55 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    whats one cost for a taco i was going to look at making something like that this week
  10. Nov 24, 2009 at 8:54 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    This definitely reinforces that area for the driveshaft. And yes, longevity will be a benefit too if your shaft behind the bearing is at an angle that's noticeably different than the front section. I like about a 2-3 degree difference. I can explain how to determine this if needed. This bracket comes with grade 8 mounting hardware and pricing is as follows..As much as I want to offer it for less, materials and time say otherwise. Pictured is my first one for a friend, they'll have a couple refinements and be a bit cleaner now too.
    Bracket $61.95
    USPS priority medium flat rate w/delivery # $16.80
    Total $78.75
  11. Nov 24, 2009 at 8:58 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    and that will stop alot of the drive line vibs
