Beefier Fuel pump upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by License2Ill, Jan 22, 2019.
  1. Jan 22, 2019 at 4:57 PM
    License2Ill
    License2Ill [OP] Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Anybody have any recommendations ?
    Trying to stay away from Walbro, I like their specs. But I hear they're garbage.
    My fuel pump is taking a shit ATM.
    Tia for any recommendations!
  2. Jan 23, 2019 at 12:45 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    IMO a problem is too much "beef", even supercharged we do not need much more pump so the Wally 190lph seems sufficient. But that said, I'm partial to DW pumps, for us the dw200 would have similar fitment as putting a Wally in, but the flow of a Wally 250 I believe. I have a DW300 in the IS300 and it has been great, and quiet compared to Wally. Another pro to avoid Wally is the DWs are flex fuel friendly if u get the e85 bug.
    AEM, aeromotive and a number of others all seem to get their pumps from the same supplier but I like DW, they actually did stress tests before releasing it.
    License2Ill[OP] likes this.
  3. Jan 23, 2019 at 4:12 PM
    License2Ill
    Ian
    Awesome, thanks for the info. Stress test and quiet; I'm excited to here that.
    Not that I need a 200lph pump. Just a robust pump.
    I'm in the land of Range & Basin and there's no flat ground here and im around 2K lbs over a stock double cab. So I'm not surprised my pump is calling it quits (at least I hope that's my issue) after 120k miles.
    Should the DW have fit and form similar to the stock pump? Or do you believe I should invest in any adaption hardware?
  4. Jan 23, 2019 at 4:16 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  5. Jan 23, 2019 at 6:33 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I've read good things about AEM for sure, though I've never run one. I ran a few walboro 190 and 255. One or two of them would buzz/whine after running them on the HWY for a while. Others didn't...it was hit and miss. FWIW, I'd recommend AEM.
  6. Jan 23, 2019 at 8:36 PM
    eon_blue
    Azusa, CA
    I have the Walboro 190 fuel pump that came with the 7th injector...seems to do its job just fine (been installed for over a year now) but my god does it whine loud when it's hot.
    If I we're to do it again, which I might in the near future, I'll go AEM most likely
  7. Jan 23, 2019 at 8:44 PM
    BlackSportD
    Los Angeles
    DW200 has same fitment/shape as the 190 so I would invest in what the Tacoma 190 tutorials mention.
  8. Jan 23, 2019 at 8:48 PM
    eon_blue
    Azusa, CA
    Yeah my Walboro is weird, sometimes on a trail it gets so loud it almost sounds like it's screaming, other times I'll be wheeling all day and it won't make a peep. Been like that for over a year and no issues a far as fuel delivery, but it does get annoying when it's loud.
    I hadn't considered DW pumps but I'll look into them
  9. Jan 23, 2019 at 9:18 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I'm running an AEM 320 and its been just fine. My stock one was fine also, and is honestly probably just fine for even moderate turbo builds.
    tony2018 and License2Ill[OP] like this.
  10. Jan 23, 2019 at 9:20 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The Wally's are trash, they've been going downhill since the 90s. The Aeromotive 340 is a real gen though, it's quiet and performs well.
    License2Ill[OP] and eon_blue like this.
  11. Jan 24, 2019 at 5:34 AM
    License2Ill
    Ian
    Thanks for all the replies guys!
  12. Jan 24, 2019 at 5:39 AM
    1997tacomav6
    Denver
    Toyota fuel pumps don’t usually give up at 125,000 FYI they usually go the distance
  13. Jan 25, 2019 at 5:27 AM
    License2Ill
    Ian
    I have a fueling issue. A new pump is cheap enough. Hate to throw parts at it. Hopefully it's the pump. I've exhausted all other diagnosis.
  14. Jan 25, 2019 at 5:37 AM
    1997tacomav6
    Denver
    Should be easy enough to check with a fuel pressure test, I’m sure you checked the fuel regulator and vacuum to it and the fuel filter.
  15. Jan 25, 2019 at 6:03 AM
    tony2018
    tony2018 Well-Known Member
    Still got your tacoma? I haven't been following up on your build but hopefully you worked out the kinks.
    Brice[QUOTED] likes this.
  16. Jan 25, 2019 at 9:14 AM
    License2Ill
    Ian
    Filter is a year old. Haven't tested the regulator.
    AutoZone rent that kinda thing?
    Brice likes this.
  17. Jan 25, 2019 at 9:20 AM
    Brice
    Brice Turbo Member
    Brice
    Texas
    They do rent a fuel pressure tester, but you'll have to tap a rubber fuel line to read the pressure. From my research you'll be looking for 38-43 psi
    License2Ill[OP] and 1997tacomav6 like this.
  18. Jan 25, 2019 at 9:20 AM
    Brice
    Brice Turbo Member
    Brice
    Texas
    I do still have it :D. The build page hasn't been updated in quite some time however.
  19. Jan 25, 2019 at 4:22 PM
    License2Ill
    Ian
    Yeah I figured I'd have to monkeyrig it. Stupid as it sounds I'd rather swap pumps and/or buy a new pressure regulator than bother testing it.
    Thanks for the pump recommendations guys I'll look into each of what was mentioned.
