Been doing it wrong for 106k miles. . .
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, May 9, 2010.
  1. May 9, 2010 at 9:05 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Ok, so I've changed my oil myself every 3-5k miles since new in '06, except maby 3 or 4 times. My truck has 106k miles on it now. I never really knew how much oil to put in (manual says 4.8 and 5.2 qts.), so I just put 5 quarts into it because it looked good on the dip stick, and I don't have to buy an extra quart. Now, I just read the DIY oil change for giggles, and says to use 5.5 qts. . . :frusty:
    4.8 qts?
    5.2 qts?
    5.5 qts?
    or
    5 qts ok?
  2. May 9, 2010 at 9:06 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I use 5.5 and its good on the dipstick
  3. May 9, 2010 at 9:06 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    half a quart isn't that big of a deal. Just start adding the extra half from now on.
  4. May 9, 2010 at 9:11 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    5.5 it is :(
    damn half a quart. arggggggggggggg
  5. May 9, 2010 at 9:56 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    What's the big deal?
  6. May 9, 2010 at 9:59 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    i dunno.
  7. May 10, 2010 at 1:33 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    At least it was only half a quart. And at least you read the manual to many people dont even bother to read it. But your Taco should be fine just add the extra quart from now on! :D
  8. May 10, 2010 at 1:38 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you've went 106 without issues no reason to beat yourself up. It is 5.5 quarts almost dead on... that said even a quart low you can probably get away with. As long as the pump can get to the oil at all times it can do it's job... there is a safety margin there.
  9. May 10, 2010 at 1:53 AM
    1980 Well-Known Member
    The Dust Bowl
    As long as you are not parked on a steep incline, if the oil level looks good on the dipstick then it's good, unless you have the wrong dipstick. There is a good bit of "wiggle room" engineered into required oil levels, if there wasn't then the engine would have to be sealed as non-user serviceable. 5 quarts puts me exactly half-way into the "OK" region of the dipstick.
  10. May 10, 2010 at 2:04 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    It's not sealed and is serviceable... it's just not as obvious as most. Look up the write-ups on here for it :D
  11. May 10, 2010 at 2:37 AM
    The Dust Bowl
    Drain and refill with oil filter change 5.2 liters (5.5 US qts, 4.6 lmp. qts)
    Drain and refill without oil filter
    change 4.9 liters (5.2 US qts, 4.3 lmp. qts)
    Dry fill 6.0 liters (6.3 US qts, 5.3 lmp. qts)
    I run my engine until its warm then drain the oil. Unlike some others I don't let it drip forever so there's probably a bit of oil up in the engine still as a 5-quart oil jug fills me up just fine. If you want to be nit-picky and let the oil drip for an hour and then top it off with an extra half quart from an additional jug it's probably OK too. I figure that extra half quart of "dirty" synthetic left in my engine is probably not going to do much harm when the oil gets changed at well less than half its serviceable life anyway.
    I use a 5-quart jug
  12. May 10, 2010 at 4:51 AM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    LOL I used to put 15qts into my diesel...Talk about Cha-ching.
  13. May 10, 2010 at 5:26 AM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    just buy a bottle of STP oil treatment and add to every oil change...That will give you the extra .5 quart, plus some extra protection.
    Boy, i know im gonna get reamed for this one...lol
  14. May 10, 2010 at 9:49 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    used 5 qrts on my last change and it's half way in between low and high on the stick...
  15. May 10, 2010 at 9:49 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Mmmmm snake oil....
  16. May 10, 2010 at 9:49 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    oh shi- Says 5.2 LITRES!!! I never even saw the 5.5 quarts haha.
  17. May 10, 2010 at 9:52 AM
    ILove2Drive
    ILove2Drive Well-Known Member
    Casey
    WV
    07 Tacoma 4X4 5 Speed Manual
    Halo headlights, Black tail light covers, dual exhaust, 5100s front and rear, eibach coils, wheelers 1.5 AAL, window tint, bow arrow antenna, bull bar, painted grille emblem, debadged, raceline rims, a few decals, CB radio, alpine HU, husky floor liners, tool box, mesh grill...and more to come eventually
    We always just put 6 quarts in my old truck 2000 3.4L and never had any problems.
  18. May 10, 2010 at 9:55 AM
    inlinejohn
    inlinejohn Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
    5.4999999999
  19. May 10, 2010 at 9:56 AM
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    I gotta 4 banger and i only put 4 with the stp treatment which is prolly a placebo but been doin it for 5 year. My old 4 banger yota only put 4 quarts in too, i dunno works for me
  20. May 10, 2010 at 9:56 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Is why you are getting 0.0 MPG ofc.
    :cool:
