been putting off doing work to the truck..
Discussion in '1st Gen. Tacomas (1995-2004)' started by wildjerseyfirefighter, May 18, 2011.
  1. May 18, 2011 at 3:29 PM
    wildjerseyfirefighter [OP] I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Since last summer..Found out one of my ac lines was busted..been putting it off ever since. I finally ordered the line tonight($83) direct from toyota, and need to do caliper(s) on friday. It should be like driving a new truck:D
  2. May 18, 2011 at 5:01 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    or at least a "cooler" truck. Good Luck
  3. May 18, 2011 at 6:15 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    ya i want to do the gray wire mod, greese all the zerks, sea-foam the engine through the brake booster, maybe deckplate mod, and of course an oil change soon.
  4. May 18, 2011 at 9:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Hey Man, would love to see some bigger pics of your truck. Looks like a beautiful impulse red pearl :D Its a great color :rolleyes:
  5. May 18, 2011 at 10:42 PM
    TRDBen
    TRDBen Mall Crawler of the Year
    Ben
    San Luis Obispo, CA
    02 Prerunner 4 Door TRD V6
    Front Window Tint KYB Monomax Shocks Blue Dome Light Valentine 1 Radar Detector
    The more 1st gen's we keep out there the better :)
  6. May 21, 2011 at 7:20 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    good news! orderd the AC line, should be here this week.
    Bad news, done my calipers tonight..Broke two of the 4 bolts that hold the caliper onto the spindle, and no one around here had them..Had to heat the ear on the spindle, and slowly work the little nub sticking out with a pair of vice grips. Im gonna go to autozone tomorrow, and another little hardware store that has everything and see if they have them..If not i guess its laid up till monday when the stealer opens...Fawkin SIHT!
  7. May 21, 2011 at 10:20 PM
    x2468
    Vermont
    Aw man. that sucks dude. sorry to hear. good luck getting the parts you need
    There are some recent pics here http://www.tacomaworld.com/forum/suspension/156844-tips-installing-front-struts-2.html
    Thanks for the compliments. Of course i love the way my truck looks. But i can't say it's anywhere near as nicely groomed as alphaecko2k5s.
  8. May 22, 2011 at 8:10 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Not true. The less out there, the more ours are worth. :D
  9. May 22, 2011 at 11:53 AM
    TRDBen
    Ben
    San Luis Obispo, CA
    Good Point!:D
  10. May 24, 2011 at 12:06 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    If anyone ever has a problem with the caliper bolts, I found the only ones that fit, from Toyota. $10 for 4 bolts, and my truck is rolling again. Torque spec on the bolt is 90ft. lbs
