Been sitting a while
Discussion in '1st Gen. Tacomas (1995-2004)' started by Beerman 1001, Aug 13, 2022.
  1. Aug 13, 2022 at 5:49 AM
    Beerman 1001
    Beerman 1001 [OP] Member
    Red 2001 Tacoma
    Hi,
    Have a 2001 with about 350K on the clock. It's been sitting, unstarted for about 1 year. Going to try to get her back on the road.
    Any recommendations for starting her back up??
    Have battery charged and tested. My plan is to check and top off all fluids, and to take the plugs out and squirt some normal motor oil in the spark plug holes and rotate the crankshaft. Could someone advise me as to what size bolt and which direction I need to rotate the bolt??
    Any other tips???
    TIA.
  2. Aug 13, 2022 at 6:20 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    19 mm crankshaft bolt, facing the vehicle, turn clockwise.
    Edit: at least that’s what it is for the 3RZ I have. You didn’t mention which engine you have. I don’t know if it’s different for the other.
  3. Aug 13, 2022 at 7:10 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I not sure it has been so long since I have seen a clock with hands!
    just which direction a clock turns.
    ArizonaBrian and Black DOG Lila like this.
  4. Aug 13, 2022 at 8:00 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Clocks turn the same way as turds in the toilet when flushed in the northern hemisphere.
  5. Aug 13, 2022 at 9:52 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    The opposite of widdershins.
  6. Aug 13, 2022 at 10:00 AM
    vtwoodchuck
    vtwoodchuck Well-Known Member
    New England
    2001 Reg Cab 4wd
    Idk in my opinion one year is not that long. Check the fluids and fire that sucker up. No big deal.
  7. Aug 13, 2022 at 10:21 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    A year isn't that long. I'd be more concerned about the fuel than the oil.
  8. Aug 13, 2022 at 10:28 AM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    Funny replies but... Clockwise is to the right LOL
  9. Aug 27, 2022 at 12:36 PM
    Beerman 1001
    Red 2001 Tacoma
    Ok.. Fired her up. Got her up to temp. Cut it off after 15 minutes or so, stationary at idle.
    Turned it off, waited a few minutes, now it won't start back.
    Thoughts??? Bad gas and/or clogged fuel filter??
    What to try next.
  10. Aug 27, 2022 at 12:41 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Pull plugs and see which is wet....
    You can cut the fuel by holding down pedal at start....
    My guess is leaking injector......and thats after pulling fuel regulator and check if fuel is even flowing....
    You can pull the fuel return hose off to check....
    If it is leaking injector......should be able to clean that plug, and should fire right up...
    As a rule.....i would of put injector cleaner in that first tank.....and maybe even put some lucus conditioner in tranny for safeguard.....
    Your brake fluid has turned to crap.....all oxidized ......I would flush all....
    Same on steering....i'd do new hoses and fluid......sooner than later.....that and differentials and are expensive to replace....
    And keep an eye on rear wheel axle seals....they get brittle sitting too long....just like tires.....
    And leak is somewhat hidden at first.....stoped by that o-ring and outer hub seal......
    Leaks too long, it destroys the $100 bearing on each side.....and the shoes.....
    and without that axle tool and a shop press.....$1000 repair to have a shop do it....
    NOt to mention running the differential dry.....
  11. Aug 27, 2022 at 11:21 PM
    ArizonaBrian
    Not enough info. What's it doing? Is it a cranking no start? No crank? Engine light on? Any codes? Start with the basics: fuel. Spark, compression. Spark is easiest, and I include a battery check under the spark category. From there move on to fuel. What's your fuel pressure? Are the injectors clicking like they should?
    You did use good gas right? And not try to use the old junk that was in there,?
  12. Sep 3, 2022 at 11:33 AM
    Beerman 1001
    Red 2001 Tacoma
    Ok. 2001 saga, part 1000.
    Got it started. Think I’m home free. Then I notice the aftermarket brake booster I purchased off of fleabay has FOUR STUDS for the brake master cylinder-the old one has TWO. I did notice this booster was around 10-15% smaller diameter then the original one-but I’ve seen this before. Before I take this up with the seller, did some models come with the four studs, and not the two?? Or was I shipped the wrong part, like I suspect??
    Also where does the brake pedal return spring attach on the interior-I get that the small end goes to a pin in the brake pedal linkage, but not sure where the other end goes.
    TIA.
  13. Sep 4, 2022 at 8:22 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    $1000 is about right. I just had one of my axle seals and bearing replaced. Cost me $490 from door-in to door-out. The bearing cost $70 (included in the $490). The cost to replace just the seals without replacing the bearing would have been $225.
  14. Sep 4, 2022 at 8:25 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Just fill the tank to dilute that old gas and you should be alright. You can add some injector cleaner also if you want.
  15. Sep 17, 2022 at 8:09 PM
    Beerman 1001
    Red 2001 Tacoma
    Couple of more questions.
    Swapping out old brake master cylinder. Old MC had a round rubber grommet. New one I purchased does not. The old one is in poor condition-I think it was the source of my brake fluid leak. Necessary item?? Does it make sense that the new one doesn’t come with this item??
    Also, there is a switch that cuts off the brake lights on the upswing of the brake pedal. Looks like there’s a rubber bumper of some sort- my bumper, for lack of a better term, seems to have crumbled away. What would I call this item, when seeking a replacement??
    TIA.
