Beep, Beep, Beep while Braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FishaRnekEd, Sep 18, 2014.
  1. Oct 6, 2014 at 9:08 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    So it's fixed???
  2. Oct 6, 2014 at 10:44 AM
    FishaRnekEd
    FishaRnekEd [OP] Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    No, not at all
    all I did in that vid was take the whole dash apart to take a look.
    right at 49 seconds, you can see what it is doing when I use the turn signal and brake
  3. Oct 6, 2014 at 10:56 AM
    FishaRnekEd
    New Orleans, LA
    Yes, I just got done finding wires that were "tapped" into, and then cut/left exposed.
    It looks like they wired in stereo/amp crap. And then cut the wires to get the amp and whatever else out before they sold the truck.
    Just made a second video to show what I found.
    http://youtu.be/q7QjVsr5ObE
  4. Oct 6, 2014 at 11:11 AM
    GrtSaint72
    GrtSaint72 Well-Known Member
    Darrell
    Ewa Beach, Hawaii
    14 DCSB TRD Sport
    I didn't think you can have cruise control in a manual transmission vehicle.
  5. Oct 6, 2014 at 11:38 AM
    FishaRnekEd
    New Orleans, LA
    I am not the first owner. but maybe its aftermarket?
    it looks to have been a factory fit. its not all jerry rigged like the wiring for the stupid ass amp and what not.
  6. Oct 6, 2014 at 11:44 AM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    I have cruise control in my manual
  7. Oct 6, 2014 at 12:22 PM
    FishaRnekEd
    New Orleans, LA
  8. Oct 6, 2014 at 12:25 PM
    Tacoma Mike
    Southern Maine
    Remote start ring
    FishaRnekEd[OP] likes this.
  9. Oct 6, 2014 at 12:39 PM
    Canufixit
    New England
    Well, I had, what I could find, for Taco schematics - but I trashed them. From What I remember looking at the gauge cluster , it is called the "combination meter?" in the prints. This module has the beeper in itself (and the gauges). Where I was, I was trying to check the input wiring / names/ functions and colors. I figure the issue is a miss wire going in from the botched radio install or a bad "combination meter? (which is big $$).
  10. Oct 6, 2014 at 1:55 PM
    GrtSaint72
    Darrell
    Ewa Beach, Hawaii
    14 DCSB TRD Sport
    Sorry I am wrong you can have the cruise control in manual. How does it work though? Doesnt cruise control work with the engine and transmission to hold the speed?
  11. Oct 6, 2014 at 2:13 PM
    Tacoma Mike
    Southern Maine
    Same as an auto.
    The difference is two switches on the pedals.
    One for brake, one for clutch to disengage.
  12. Oct 6, 2014 at 2:35 PM
    FishaRnekEd
    New Orleans, LA
    I have cut wires that were tapped into the clutch sensor. Was that for the cruise control?
    when it does work, it disengages with the brake as it should. but I never pushed the clutch to check if that disengaged it.
  13. Oct 6, 2014 at 3:23 PM
    Tacoma Mike
    Southern Maine
    Something to check. It needs to disengauge or else you will get a hi engine flair when u push the clutch in.
    Needs to be there...
    The remote start for a std trans needs to see extra inputs to activate.
    The extra wires can go but the clutch switch needs to be there or else it won't start
  14. Oct 6, 2014 at 5:33 PM
    FishaRnekEd
    New Orleans, LA
    Good to know, but they pulled the security system, remote starter, amp, and what ever else...
  15. Oct 6, 2014 at 5:34 PM
    #35
    FishaRnekEd
    New Orleans, LA
    I PULLED OFF THE BACK RIGHT TAIL LIGHT ASSEMBLY. LOOKED AT IT, DIDNT DO SHIT TO IT, AND PUT IT BACK ON.
    AND IT DOES NOT BEEP WHEN I USE THE RIGHT SIGNAL AND BRAKE ANYMORE.
    WTF?
  16. Oct 6, 2014 at 6:55 PM
    #36
    Tacoma Mike
    Southern Maine
    Hehehehehe you have a aftermarket trailer wiring in there ???
  17. Oct 6, 2014 at 7:48 PM
    #37
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Maybe wire back there is frayed to the point its hitting metal somewhere. Maybe you just happened to move it around just enough to get it away from contacting. :notsure:
  18. Dec 27, 2014 at 7:54 AM
    #38
    FishaRnekEd
    New Orleans, LA
    no, not in the tail light.
    stock trailer wiring
    but the tail light its self is not original (probably non Toyota)
    it was cracked and I replaced it MONTHS before it gave me the beep
  19. Dec 27, 2014 at 7:56 AM
    #39
    FishaRnekEd
    New Orleans, LA
    That makes the most sense
    funny thing is, its been months of rough roads, and still no problem. but that's good.
    now I gotta fix the P043E check engine light code...
  20. Aug 11, 2016 at 4:52 AM
    #40
    FishaRnekEd
    New Orleans, LA
    Update, 2 years later...
    It was beeping again.
    I removed the tail light.
    I took the wiring plug apart, inside the plug where the pins are crimped on the wires, they CRIMPED THE RUBBER BOOD IN BETWEEN THE WIRE AND THE PIN instead of slipping the boot on afterwards.
    LmFao, for 2 years this minor quality assurance issue had me stumped just because some ahole in the factory was hung over.
    Cruise control still doesn't work
    Jimmyh likes this.
