Beep, Beep, Beep while Braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FishaRnekEd, Sep 18, 2014.
  1. Aug 11, 2016 at 6:23 AM
    #41
    whipper
    whipper Well-Known Member
    2007 PreRunner
    I believe there is a TSB for the clock spring in the steering wheel. In you video you mentioned it was working on and off. This might cause the intermittent problem you describe.
    Good luck.
  2. Aug 11, 2016 at 3:56 PM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Thanks for the update! Good you found it, even if it took two years. :)
  3. Aug 14, 2016 at 7:49 AM
    #43
    FishaRnekEd
    FishaRnekEd [OP] Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Thanks for chiming in. read post 41 though, I finally figured it out!
  4. Aug 14, 2016 at 11:08 AM
    #44
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    As do I... Where the hell did u hear that theory?
