Beep Sound When Hitting Bumps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Jul 25, 2011.
  1. Jul 25, 2011 at 12:15 AM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    Sometimes when I hit a bump a little electronic beep sounds off somewhere. I'm not even offroading or speeding, just regular driving, a small bump might set off the beep. So far its only happened sometimes, in 2wd, straight line driving.
    Is this normal? Where's it coming from?
  2. Jul 25, 2011 at 12:46 AM
    JKD
    JKD Well-Known Member
    No, not normal in regular driving. Do you feel any of your brakes activating or do you feel a 'growl' sound from the truck when that beep happens?
  3. Jul 25, 2011 at 1:07 AM
    tacomtn
    No, I dont hear those other sounds you're describing, only the single beep. It happens intermittently.
  4. Jul 25, 2011 at 1:11 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Gremlins? Idk. Never heard beeps before.
  5. Jul 25, 2011 at 1:21 AM
    dep3091
    dep3091 Well-Known Member
    Southern Inland Empire
    White 05 Tacoma 4x4 LongBed
    2.5" Donahoe/Icon Front Coilovers, Icon Rear Reservoirs, K&N Filtercharger, Magnaflow Cat-Back, Bajarack Mule mounted over Bed on Thule Xsporter, Bajarack Dual Fuel/H20 Can holder, All-Pro front bumper w/PIAA Fogs, KC Rallye 800 Pencils, Custom Windshield Crack
    My driver window squeaks...kinda sounds like a beep.
  6. Jul 25, 2011 at 1:57 AM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I'm guessing it's your VSC skid alarm. If you hit a bump just right it can jar the VSC yaw sensor enough to momentarily fool it into thinking that the truck is entering an incipient skid. Usually it happens to me when I hit a bump on a curve tho, not while driving straight.
  7. Jul 25, 2011 at 5:33 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Parking brake barely engaged?
  8. Jul 25, 2011 at 7:06 AM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    This is the only time when I hear it go off. Only when I bump a curb...
  9. Jul 25, 2011 at 7:10 AM
    GatorComa
    GatorComa Well-Known Member
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    The same thing happens with my truck. There's one specific turn in my neighborhood that I guess gives just the right bump for my VSC to engage. Always scares me haha. But I haven't had it do that just driving on the road with small bumps.
  10. Jul 25, 2011 at 8:58 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Before driving over that bump next time, fully stop the truck and hold in your VSC OFF switch for a few seconds (until lights come on indicating you are in VSC OFF MODE... Now drive over that bump as before... This may tell you if it is a stability sensor, alerting you that the VSC has just saved you from rolling over, etc. :eek:;) Maybe there is a small curve along with the bump, and that combination puts the VSC into action?
    My VSC beeper rarely goes off... Only on rainy days when I take a turn too fast, and it prevents the truck from spinning out or when four wheeling on loose terrain and sloshing around will make the thing beep,beep,beep.
  11. Jul 25, 2011 at 9:53 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It is the VSC
    Have you lifted your truck or put on bigger tires than stock ?
  12. Jul 25, 2011 at 10:29 AM
    tacomtn
    Stock everything.
  13. Jul 25, 2011 at 10:35 AM
    OZ-T
    Peter North
    British Columbia
    The VSC will sound a very faint beep without engaging , I think this occurs when you are approaching the parameters where the VSC actually engages .
    This faint beep is different than the loud beeping and light flashing that occurs during VSC engagement , which you also feel through the pedals similar to when ABS engages .
  14. Jul 25, 2011 at 10:41 AM
    BenWA
    Boston burbs
    It used to happen to me on occasion when I was still stock.
  15. Jul 25, 2011 at 10:49 AM
    David K
    Interesting... I have never heard the faint beep...???
  16. Jul 25, 2011 at 10:53 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    You skipped light speed and went straight to ludicrous.
  17. Jul 25, 2011 at 11:04 AM
    BenWA
    Boston burbs
    Me neither. Probably because I have my stereo cranked to 45 most of the time.
  18. Jul 25, 2011 at 11:08 AM
    David K
    You may be correct!:eek:
  19. Jul 25, 2011 at 12:15 PM
    OZ-T
    Peter North
    British Columbia
    It happens .
    There is a particular corner that makes my VSC engage if I am going over 40 MPH , if under 40 MPH there is no engagment only a very faint servo / beep noise .
  20. Jul 25, 2011 at 12:16 PM
    OZ-T
    Peter North
    British Columbia
    Keep firing Assholes !
