Beeping 4x4 switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by squiggy, Nov 16, 2010.
  1. Nov 16, 2010 at 4:19 PM
    squiggy
    squiggy [OP] Well-Known Member
    Vermont
    2012 Tacoma Access Cab
    none yet
    Does anyone know if there is a way to stop the annoying beeping sound when you engage your 4 low on the 4 wheel drive switch ?
  2. Nov 16, 2010 at 4:26 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    The beeping is for your protection... It is saying "Hey dummy, you're doing something wrong!" But I guess you could take out the beeper...
  3. Nov 16, 2010 at 4:30 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    he speak the truth:D
  4. Nov 16, 2010 at 4:32 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    If you don't engage the 4wd right she beeps
  5. Nov 16, 2010 at 4:36 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Yep, it wouldn't be beeping in the first place unless your doing something wrong. In the 3 years I've had my truck I don't remember ever hearing any beeping when engaging 4WD.
    I've read with the manuals the clutch pedal needs to be all the way in against the floor.
  6. Nov 16, 2010 at 5:31 PM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
    Yeah, what they said. I do have to confess though I did the same thing this weekend when wheeling and forgetting to slap it in neutral first. If you follow the steps that are on the drivers sun visor you will be ok and stop the beeping.
  7. Nov 16, 2010 at 5:34 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    hahahahaha well atleast you got it figured out
  8. Nov 16, 2010 at 11:36 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Remember in Neutral, NOT PARK!
  9. Nov 17, 2010 at 9:17 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Just did it myself. Stuff happens.
    Thank goodness my wife checked in the manual and read the correct procedure!!!
  10. Nov 17, 2010 at 9:25 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    What the others have said. Since yours is a manual, you have to make sure the truck is stopped and the clutch is pressed all the way down as far as the pedal will go before putting it into 4lo. If it's beeping, it's not in 4lo.
  11. Nov 17, 2010 at 9:30 AM
    David K
    Exactly... same is true of the rear locker... if light flashes and beeping, it is not engaged.
  12. Nov 17, 2010 at 2:12 PM
    squiggy
    Vermont
    none yet
    Thanks for all the advice.....I guess I should have read the owners manual a little bit better!! I put it in 4 low this morning correctly and there was no beeping sound.....amazing. Thanks again.
  13. Nov 17, 2010 at 3:54 PM
    JanBoothius
    JanBoothius Taco abuse specialist
    Jan (Pronounced Yon)
    Salt Lake City, UT/Upstate New York
    '10 TRD Off Road Access Cab, 6 speed
    OME lift, 886 coils, Dakars w/AAL ARB front bumper, Warn M8000 winch Toyo Open Country MT 285/75R17 (34) Leer 180CC cap etc etc etc $
    Remember, don't drive on dry (or even slightly wet) pavement in 4-hi, or 4-lo.
  14. Aug 27, 2011 at 5:03 PM
    mwtaco
    mwtaco Well-Known Member
    07DCSB Black
    why cant u drive on dry pavement in 4lo or 4 hi if u r going straight?
  15. Aug 27, 2011 at 5:08 PM
    David K
    It's your truck, do whatever you want...
    If 4WD was required to drive on dry pavement, wouldn't all cars have it?
    It isn't needed, and in fact will hinder your driving ability on pavement (as you will need to steer the truck at some point and part time 4WD has no middle differential to allow the front and rear driveshafts to rotate at different speed... If the tires can't slip, then you will have 'binding'... it isn't healthy, even if it doesn't do any damage.
  16. Aug 27, 2011 at 8:22 PM
    mwtaco
    07DCSB Black
    does anyone smell ass?
  17. Aug 27, 2011 at 8:23 PM
    mwtaco
    07DCSB Black
    it was my dog
