Beeping trying to put into 4-lo and doesn't stop until put to 4 hi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011TacoBeav, Sep 27, 2011.
  1. Sep 27, 2011 at 8:01 PM
    2011TacoBeav
    2011TacoBeav [OP] Well-Known Member
    Bret
    Oregon
    2012 Sr5 v6 auto DCSB
    Self made rear bumper Colormatched Bush Wackers CB Center console lock box Camo seat covers Weathertech Digi blk Bilstein 5100s set at .85 Eibach coils LR UCAs Rear 1.5" block
    Hey ya'll was curious if this was a common thing or if i'm just misusing my 4x4
    At a stop, when I attempt to put into 4 lo there is a beeping and the 4 wheel symbol slowly flashes... am I attempting to but it into 4x improperly or is there something wrong.
    the beeping/flashing continues until i put it in either 4hi or 2wd...
  2. Sep 27, 2011 at 8:05 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Make sure you are off road and drive around a bit. It will lock in.
  3. Sep 27, 2011 at 8:22 PM
    2011TacoBeav
    Bret
    Oregon
    Yeah I was just doing the 4x4 lubricating as per the owners manual... I was on street driving around the neighborhood. So not sure why it wouldn't go it...
  4. Sep 27, 2011 at 8:26 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    also if your manual, you need to be pressing brake and engage the clutch all the way, not sure if you need to do the clutch but it do and never have any problems. i have a 2.7 manual 5 speed.
  5. Sep 27, 2011 at 8:27 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Shift into neutral before shifting into 4Lo
  6. Sep 27, 2011 at 8:30 PM
    middiedefense
    middiedefense like a boss
    Joe
    GA, MD
    09 Access Cab. V6, 6spd, sr5, 4x4, OME 3" kit
    OME 3" Complete kit, TRD O/R Wheels (rattle can flat black), Black Badges, Ultra Gauge
    Yea read your visor instructions. Also shouldn't be on if not in conditions that cause slippage on tires, could be potentially harmful
  7. Sep 27, 2011 at 8:37 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    I just saw that the OP has a manual transmission. For automatics, shifting into neutral before switching the dial to L4 is standard procedure.
  8. Sep 27, 2011 at 8:44 PM
    2011TacoBeav
    Bret
    Oregon
    haha.... I skimmed it...
    I actually found out that were supposed to run the 4x4 every so often as per the manual via a member on this forum... haha
    Seriously though thank you for your help!!
  9. Sep 27, 2011 at 10:01 PM
    2011TacoBeav
    Bret
    Oregon
    Why is it that you're not supposed to turn? locking diff?
  10. Sep 28, 2011 at 11:52 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    The Transfer case is where the front and rear drive shafts are 'locked together'... the differentials are open. The two drive shafts rotate at different speeds so when you turn on dry pavement, there is binding as the tires won't be able to slip... since the front tires rotate more than the back when turning.
    Read Christian's link like he's been asking you to!
