beertime's buildthreadcontinuum and DYF BS
Discussion in '2nd Gen. Builds (2005-2015)' started by beertimecontinuum, Mar 21, 2016.
  1. Aug 6, 2017 at 3:16 AM
    #3001
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Dood! Those springs are fuct.... I'm ordering All Pro's on Monday.
    Very productive looking group of "technicians"...... Rear gear install not bad....Front is just a little more "involved". Glad I already have that part behind me....You been able to test drive 'em yet?
    Show up @ my place next. Front bumper install tentatively scheduled for next Saturday. Will be in "the paint shop" (Part of garage with plastic paint booth hung from ceiling) all week. Ready for assembly by Thursday or Friday. On the truck by this time next week. I'm building a cart to hold bumper @ desired height. Just roll it up and bolt it up...
    beertimecontinuum[OP] and MarX like this.
  2. Aug 6, 2017 at 5:38 AM
    #3002
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    MarX likes this.
  3. Aug 6, 2017 at 5:42 AM
    #3003
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Did you loosen LCA bolts? (Some people do, some don't... I leave mine alone.) Sounds like another trip to the alignment shop.
    While I have everything apart to swap in the 887's, gonna put extended top studs on just in case I decide to stack more plate spacers in at a later date. I'm hoping with aluminum bumper and skids, 887's will get me to sit about where the 885's are now. If not, 1/2" poly spacers on both sides. Not using 886's...Not preloading coils any more than 0" either.....
    Aluminum bumper almost 60lbs lighter than steel. Aluminum skids almost 60lbs lighter. Warn winch 22lbs heavier (89lbs) than Smittybilt (67lbs). Trying to calculate added load to front end. .....around 140lbs.
    MarX likes this.
  4. Aug 6, 2017 at 6:31 AM
    #3004
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Probably vvvv
    We did on the drivers side but not passengers. Alignment wasn't bad on the initial test drive but that was ~30mph on backroad. We marked the cams and lined it back up as well as possible for the drive home.
  5. Aug 6, 2017 at 6:51 AM
    #3005
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I fabbed a bracket that catches the LCA and holds the business end of an 8' spud bar. All I need is someone to step on the end of that and it pulls LCA far enough out of the way to put a strut in place without loosening the LCA bolt. Speeds up the operation quite a bit.
  6. Aug 6, 2017 at 6:58 AM
    #3006
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Ratchet strap from one LCA to the other. Pry bar/large screwdriver/penis/etc. to line the lower shock mounting hole up.
  7. Aug 6, 2017 at 7:22 AM
    #3007
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Shimmy from loosening the driver's cam bolts most likely. Haven't gotten out of bed yet to visually inspect anything yet, tired.
    No knocks, clunks, or creaks the whole way back. Much smooth!
    Thanks again for the help guys! Glad we got Everett's heavy lifting done too!
  8. Aug 6, 2017 at 7:52 AM
    #3008
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Where's the pics of people falling asleep with inappropriate penmanship on their face?
    Epic fail lol:rofl:
    Actually looks JK looks like an awesome time.
    beertimecontinuum[OP] likes this.
  9. Aug 7, 2017 at 12:48 AM
    #3009
    beertimecontinuum
    beertimecontinuum [OP] What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Stolen from @Crom :cheers:
    Brake Parts!
    Below is a complete parts diagram for the brake system for my truck, looks good for 2008-2011. Should be good for any TRD OR 4x4 truck, I would think.
    One good thing about Toyota, is they don't charge too much for brake line tubing. It's already pre-bent and flared with flare nuts installed.
    Just cut out the old and replace. o_O So fun! :rolleyes:
    Code:
    Name and number Request Price
    47311A Way(for Front Brake Tube)
    90412-10247
    2
    US $10.22
    47312 Tube, Front Brake, No.2
    47312-04140
    47312-04150
    47312D Way, 2(for Rear Brake Tube)
    90412-10248
    47313 Tube, Front Brake, No.3
    VSC-WITH(W/AUTO LSD);VSC-WITH(W/DOWNHILL ASSIST CONTROL);VSC-WITH
    47313-04200
    47313-04190
    47313-04210
    47313A Hose, Flexible, No.1(for Front)
    FLEXIBLE, NO.1(FOR FRONT)
    90080-94073
    2
    US $19.29
    47314 Tube, Front Brake, No.4
    47314-04150
    47315 Tube, Front Brake, No.5
    47315-04170
    47315-04160
    47315-04180
    47316 Tube, Front Brake, No.6
    47316-04150
    47316A Hose, Flexible(for Rear Brake Tube)
    LH
    90947-A2003
    RH
    90947-A2004
    47317 Tube, Front Brake, No.7
    47317-04050
    47318 Tube, Front Brake, No.8
    47318-04110
    47321 Tube, Rear Brake, No.1
    47321-04110
    47321-04180
    47323 Tube, Rear Brake, No.3
    47323-04170
    47323-04160
    47323-04180
    47324 Tube, Rear Brake, No.4
    47324-04130
    47324-04120
    47324-04140
    47325 Tube, Rear Brake, No.5
    47325-04170
    47325-04200
    47326 Tube, Rear Brake, No.6
    47326-04140
    47326-04170
    47327 Tube, Rear Brake, No.7
    47327-04060
    47328 Tube, Rear Brake, No.8
    47328-04020
    47351 Bracket, Flexible Hose(for Front Rh)
    47351-04040
    47352 Bracket, Flexible Hose(for Front Lh)
    47352-04040
    47353B Bracket, Flexible Hose, No.3
    47353-04010
    47354 Bracket, Front Flexible Hose
    47354-04010
    47355 Bracket, Flexible Hose, No.2(for Front)
    47355-04020
    47356 Bracket, Flexible Hose, No.6
    47356-04010
    47356-04011
    47371A Clamp, Brake Tube, No.1
    90949-A4002
    90949-A4003
    90949-A1023
    47371B Clamp, Brake Tube, No.6
    90949-A4005
    90949-A4004
    3
    90949-A1024
    3
    47371C Clamp, Brake Tube, No.1
    90949-A4008
    47371D Clamp, Brake Tube, No.8
    90949-01C95
    US $4.95
    47371F Clamp, Brake Tube, No.10
    90949-A1006
    3
    47371G Clamp, Brake Tube, No.7
    90469-A0004
    3
    47371H Clamp, Brake Tube, No.9
    90461-08690
    4
    US $1.81
    90119A0169 New Genuine Part 1
    90119A0174 New Genuine Part 1
    US $1.15
    90119A0178 New Genuine Part 1
    90468A0007 New Genuine Part 1
    replacement
    New Genuine Part
    90468-08035
    US $1.65
    9008011199 Bolt (for Transmission Control Cable Bracket) 1
    US $0.82
    dirty deeds and MarX like this.
  10. Aug 7, 2017 at 1:11 AM
    #3010
    beertimecontinuum
    Everett
    Having trouble finding an OEM front shock lower mounting bolt/nut?? All the diagrams I find do not show it or list it. I have axces to lots of nuts and bolts but trying to do OEM if possible. Anybody ever order one?? Trying not to go to the dealer...
  11. Aug 7, 2017 at 2:08 AM
    #3011
    NKYTaco
    NKYTaco Well-Known Member
    Brandon
    South Eastern Indiana
    2014 MGM TRD Pinstripe Edition
  12. Aug 7, 2017 at 3:54 AM
    #3012
    beertimecontinuum
    Everett
  13. Aug 7, 2017 at 3:57 AM
    #3013
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Won't work....Diagram shows it WITH sway bar. :rolleyes:
  14. Aug 7, 2017 at 4:10 AM
    #3014
    beertimecontinuum
    Everett
    Lol. It DOES say they're for the 4runner, pretty sure it's the same though.
    NKYTaco likes this.
  15. Aug 7, 2017 at 4:24 AM
    #3015
    NKYTaco
    Brandon
    What's a sway bar? :notsure:
    dirty deeds and 11TRDTX like this.
  16. Aug 7, 2017 at 4:25 AM
    #3016
    beertimecontinuum
    Everett
    I have one for sale :D
  17. Aug 7, 2017 at 4:37 AM
    #3017
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Used to be a bar across the street from a figure 8 race track in Clarksville Indiana called the Sway Bar
  18. Aug 7, 2017 at 5:21 AM
    #3018
    beertimecontinuum
    Everett
    Good spot for a meet?? ....or meat??
  19. Aug 7, 2017 at 6:08 AM
    #3019
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    both?
  20. Aug 7, 2017 at 6:31 AM
    #3020
    dirty deeds
    Nick
    Eastern KY
    Huh?
    No one stayed the night
    MarX[QUOTED] likes this.
