beertime's buildthreadcontinuum and DYF BS
Discussion in '2nd Gen. Builds (2005-2015)' started by beertimecontinuum, Mar 21, 2016.
  1. Feb 5, 2017 at 5:38 PM
    #521
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I'm on Dakars using original stock rear stops. Likely my rear shocks are acting as bump stops back there. :anonymous:
    I'll wait til I get new rear shocks to worry about rear bumpstops. Meaning when I see oil or hear knocking from those shocks.
    Bluegrass Taco and 11TRDTX like this.
  2. Feb 5, 2017 at 5:41 PM
    #522
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    You guys can't turn of trac control? Thought we all had a switch?
  3. Feb 5, 2017 at 5:41 PM
    #523
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Stop completely, hold traction button for 5 seconds, drift away. Works for me anyway. Trac doesn't come on again until I push the button or turn off the truck.
    beertimecontinuum[OP] likes this.
  4. Feb 5, 2017 at 5:58 PM
    #524
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Ok. I was thinking to be able to do it while moving.... example: on march 16, 2017, whatever the time will be, the memphis convoy will reach neville bay road from the trace, at which point gideon will proceed to drift onto the gravel road that is neville bay road. I plan on following suit, however, i will not have time or the opportunity to stop and turn off traction control. I suppose I'll just have to press the switch before we leave the gas station or store (whichever is our last stop) in murray and do that leg of the trip that way.
  5. Feb 5, 2017 at 6:01 PM
    #525
    dirty deeds
    Nick
    Eastern KY
    You overcome trac control with moar speed! Just don't be skeert and hammer down, then cut the wheel and watch er sliiiiiiide!
  6. Feb 5, 2017 at 6:05 PM
    #526
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    I know that. I ain't scared neither. Just want to be able to maintain the drift without the truck bitchin about it and cutting me off like a bar tender.
    dirty deeds[QUOTED] likes this.
  7. Feb 5, 2017 at 6:10 PM
    #527
    dirty deeds
    Nick
    Eastern KY
    Feels.
  8. Feb 5, 2017 at 6:11 PM
    #528
    beertimecontinuum
    beertimecontinuum [OP] What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    My truck suffered from the Yaw sensor issue that can't be fixed by recalibration or replacement. Symptoms were brakes being a plied to one front wheel while on curvy roads or exit ramps, throttle limited hard when turning/offroading. Pushing the button did nothing, holding it in while stopped made it drivable but still noticable, green wire mod knocked it out completely.
  9. Feb 5, 2017 at 6:12 PM
    #529
    dirty deeds
    Nick
    Eastern KY
    Damn man. That sounds terrible
  10. Feb 5, 2017 at 6:26 PM
    #530
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Thanks for the support and the link Everett. I'm going to do crom's method now that I've reread it and now understand it.
  11. Feb 5, 2017 at 6:30 PM
    #531
    beertimecontinuum
    Everett
    I BELIEVE in you Mike, you can DO iiiiiiit ! !!!
    11TRDTX[QUOTED] likes this.
  12. Feb 5, 2017 at 6:35 PM
    #532
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    This will be easy now that i understand the mod. I've probably added somewhere around 180 feet of wire to my truck :cookiemonster:
  13. Feb 5, 2017 at 9:52 PM
    #533
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Or you could just do locker anytime...which kills the ABS and traction control...and hit the switch when you turn onto Neville Bay Rd, and drift with TWO powered wheels.
  14. Feb 5, 2017 at 10:30 PM
    #534
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Do the TX pro's come with an e-locker?
  15. Feb 6, 2017 at 4:30 AM
    #535
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    It depends. They did make prerunners in the tx and tx pros, but not sure about the sport. Mine is basically an offroad that has the tx stuff: rims, steps, exhaust tip, and stickers. I believe mine was the first year the did the tx/tx pro which is the predecessor to the trd pro.
    Dave41079 and ChadsPride like this.
  16. Feb 6, 2017 at 4:30 AM
    #536
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    I believe the Tx package starts with a TRD off-road and adds small lift, TRD catback exhaust and graphics. He should have locker at minimum. Idk if '11s had ATRAC though?
    Edit: :rolleyes:
  17. Feb 6, 2017 at 4:32 AM
    #537
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    '11 OR's have ATRAC, so.....guessing Tx does too?
    Breezy[QUOTED] and ChadsPride like this.
  18. Feb 6, 2017 at 4:39 AM
    #538
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    have a-trac, locker, down hill assist.... all that shit. The my tx still had the stock off road suspension. The exhaust is the difference between a tx and a tx pro. Mine just had a round tip, where the tx pro has a cat back with an oval tip that has trd stamped into it.
    ChadsPride likes this.
  19. Feb 6, 2017 at 4:42 AM
    #539
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    They made shit so complicated with the 2nd gens.
    ChadsPride and Bluegrass Taco like this.
  20. Feb 6, 2017 at 4:43 AM
    #540
    Bluegrass Taco
    Bill
    Mt Washington Ky
    We're complicated people.....us 2nd gen owners.....
    presta24 and ChadsPride like this.
