beertime's buildthreadcontinuum and DYF BS
Discussion in '2nd Gen. Builds (2005-2015)' started by beertimecontinuum, Mar 21, 2016.
  1. Apr 5, 2017 at 8:17 AM
    #1161
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Sounds like a grand plan!
  2. Apr 5, 2017 at 8:19 AM
    #1162
    beertimecontinuum
    beertimecontinuum [OP] What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    @mwc273 the 6" spring ended up being 4". Everywhere I look it says it's THE spring for my aplication. Am I thinkin about this wrong? Where do you start/end the measurement? Static ball on the whip to the spring is 102" + 4" spring is 106" + 1.25 mounting stud is 107.25". I'm told I can tune by reducing the length of the cable (it's a solder joint). Does that make any sense :)
    ChadsPride likes this.
  3. Apr 5, 2017 at 8:34 AM
    #1163
    Bluegrass Taco
    Bill
    Mt Washington Ky
    In about 15 minutes I will be at a CB shop to get some info on a power mic Im interested in. ill pick his brain pn 102" wips.
  4. Apr 5, 2017 at 8:38 AM
    #1164
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Back in the day just about all commercially available antennas tuned that way.. I like the new Firesik II screw in tips
    Too easy! Any 102" I"ve ever messed with started off long.
  5. Apr 5, 2017 at 8:42 AM
    #1165
    beertimecontinuum
    Everett
    It's a non adjustable, welded type :anonymous:
  6. Apr 5, 2017 at 8:47 AM
    #1166
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I'm gonna get the 4' Firestik antenna combo. It's $55 for everything I'll need to use the tailgate mount. Comes with an 18' cable which is why I'm afraid it's short.
    My cheapo Walmart magnetic advertises 12' and it's not exactly slack when routed so as to not be in the way and still connected to my radio. Radio is velcroed to the driver's footwell carpet just below center console plastic.
  7. Apr 5, 2017 at 8:49 AM
    #1167
    beertimecontinuum
    Everett
    Perfect. I'll pick up some SS washers tomorrow or make something at work to try and get the stud to 2" for 108" total :cheers:
  8. Apr 5, 2017 at 8:50 AM
    #1168
    beertimecontinuum
    Everett
    Coool!!
  9. Apr 5, 2017 at 8:52 AM
    #1169
    beertimecontinuum
    Everett
    Wonder how I would shorten it. Cut the static ball off the top, cut out a length the weld it back? Not sure if I can even weld SS in the yard. Can at work I guess.
  10. Apr 5, 2017 at 8:58 AM
    #1170
    beertimecontinuum
    Everett
    :violent:
  11. Apr 5, 2017 at 9:06 AM
    #1171
    beertimecontinuum
    Everett
    Read that somewhere too lol, had already bought this one. Tanks for all the info!!
  12. Apr 5, 2017 at 9:08 AM
    #1172
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    i did
  13. Apr 5, 2017 at 9:33 AM
    #1173
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
  14. Apr 5, 2017 at 9:39 AM
    #1174
    presta24
    chris
    Cincinnati
    you're just compensating for something :boink:
    ChadsPride and dirty deeds like this.
  15. Apr 5, 2017 at 1:11 PM
    #1175
    Bluegrass Taco
    Bill
    Mt Washington Ky
    OK...I got a few pointers from a pro....Not sure how much I remember....But we'll see Saturday.
    I now have a 28 watt radidio! It rocks! Took him all of 5 minutes to hot rod my Cobra 25XLT. (5 watts "out of the box") He checked my work on antenna tune. It was spot on. Checked ground on my antenna mount. AOK. All good. No need for a power mic. Just as I got there, he was finishing an install in a semi. He drove off just as I started putting my radio back in the truck. When I did a radio check, the truck driver was 11 miles away, in a rural area. I was "modulating" loud and clear.
  16. Apr 5, 2017 at 1:11 PM
    #1176
    Bluegrass Taco
    Bill
    Mt Washington Ky
    That must be what they were talking about when I heard you have "plenty of ground clearance".....
  17. Apr 5, 2017 at 7:08 PM
    #1177
    presta24
    chris
    Cincinnati
    Everett must have slept in or something. He's usually up to some sort of fuckery by now
  18. Apr 5, 2017 at 7:10 PM
    #1178
    beertimecontinuum
    Everett
    Been and will be a busy night here. Hiding for a smoke now :ballchain:
  19. Apr 5, 2017 at 7:12 PM
    #1179
    dirty deeds
    Nick
    Eastern KY
    I bet the tank trap river is flowing good!
  20. Apr 5, 2017 at 7:14 PM
    #1180
    beertimecontinuum
    Everett
    Not too bad when I left. The last time washed it out reeel goood. You guys will be stuck for sure :)
