Before and After lift with question on wheels
Discussion in 'Suspension' started by awoit, Feb 4, 2013.
  1. Feb 4, 2013 at 11:33 AM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
    Installed toytec 3" w/ rear AAL.
    Now my question is what is the largest tire I can fit on my truck?
    And what is the largest tire that will work with the stock rim, or do I need to go with a bigger rim to get a bigger tire.
  2. Feb 4, 2013 at 11:34 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    255/85/16
  3. Feb 4, 2013 at 11:36 AM
    cgs2k2
    cgs2k2 old man
    I think he had a typo -
    ****255/85r16
    This is a 33" tire but is skinnier than 285/75r16 which results in less/no rubbing
  4. Feb 4, 2013 at 11:36 AM
    OZ-T
    Peter North
    British Columbia
    Yep
    Fixed
  5. Feb 4, 2013 at 11:47 AM
    awoit
    CA
    08 TRD, SR5
    Thanks guys,
    So I could still run a 285/75r16, if I wanted a thicker/wider tire.. I would just rub a little? I want a bigger tire but I don't want to lose the beefy wide look
  6. Feb 4, 2013 at 11:52 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    you can run a 285/75/16 and do a little trimming and maybe a cmc and be fine
  7. Feb 4, 2013 at 12:10 PM
    cgs2k2
    cgs2k2 old man
    right you can run the 285/75r16 and with 3inches up front you'll probably only have minor rubbing. you may have more rubbing when flexing/hitting big bumps
  8. Feb 4, 2013 at 12:13 PM
    awoit
    CA
    08 TRD, SR5
    By rubbing do you guys mean hitting mechanical parts such as upper control arms, or rubbing like taking a corner and rubbing the plastic surroundings?
  9. Feb 4, 2013 at 12:14 PM
    OZ-T
    Peter North
    British Columbia
    With a stock OEM wheel , you will need wheel spacers to run 285/75/16's
  10. Feb 4, 2013 at 12:16 PM
    veet skeet
    veet skeet Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    If you want to run 285/75r16's with your lift and stock OR rims, you're going to need wheel spacers in the front so that the tire clears the UCA. If you don't have spacers with that size of a tire and the stock rims, you're going to hit the UCA.
    I'm running 285/70r17 Goodyear Duratracs on my truck and the front is a little over 3' with my Bilstein 5100's set at .85 with OME 885x coils. I rub at full lock in reverse and had to do the cab mount chop as well as a lot of plastic trimming.
  11. Feb 4, 2013 at 12:23 PM
    awoit
    CA
    08 TRD, SR5
  12. Feb 4, 2013 at 12:24 PM
    veet skeet
    Cali
    I would recommend Spidertraxx 1.25' hub centric spacers, a lot of guys on here run them and have zero problems or complaints
  13. Feb 4, 2013 at 12:33 PM
    cgs2k2
    cgs2k2 old man
    Go with some new spacers. I've linked to the Toytec site where you can buy 'em.
    I have them - very nice. highly recommended.
  14. Feb 9, 2013 at 9:50 AM
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    Spacers in the front only or on all 4? I'm in the same situation.
  15. Feb 21, 2013 at 7:21 PM
    Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    275's ???
  16. Feb 21, 2013 at 7:22 PM
    OZ-T
    Peter North
    British Columbia
    What about them
  17. Feb 21, 2013 at 8:57 PM
    Gus 524
    Justin
    MN
    Just trying to give the guy more ideas for a wider tire with little to no trimming.
  18. Feb 21, 2013 at 9:08 PM
    OZ-T
    Peter North
    British Columbia
    I have 275/70/17
  19. Mar 7, 2016 at 3:53 PM
    shadowdobe
    shadowdobe Member
    Jim
    VA Beach
    2004 Tacoma Double Cab, 4x4
    Yakima cross bars, Curt rack, 3 inch coil over lift, 255/85r/16, home built hidden winch mount.
    Just put 255/85/16s on my 2004 Tacoma Double Cab with stock rims and a 3 inch lift. They do rub a full steering lock. They barely clear the upper control arms.
  20. Mar 10, 2016 at 10:20 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I've found Bora spacers to be equal in quality to Spidertrax and available in 3/4" and 1" (along with 1-1/4", 1-1/2") 3/4" are enough to get the job done as are the 1" and in theory, less stress on ball joints/wheel bearings etc...I did the 1" just to be on the safe side....3/4" would have been plenty. I know of 4 differet trucks running the 3/4" with no issues.
