before i buy question!
Discussion in 'Suspension' started by Toyota05zack, Dec 3, 2013.
  1. Dec 3, 2013 at 7:44 PM
    Toyota05zack
    Toyota05zack [OP] Member
    Zack
    Massachusetts
    05 reg. cab 4x4
    Bilstien 5100s, ome 884 coils, 2" aal
    ive searched and searched and cannot find anyone with this question....
    Im about to buy the bilstein adjustable lift with the 5100 shocks and aal in the back, i want to set it for 3'' in the front and the 2 in the back, the option for a top plate spacer got me thinking.....only recommended for 6cyl models, i have a regular cab 4x4 and i was wondering if i can run the 3/4 inch top plate spacer without any added front weight in order to make my truck ride a little higher in the front, is this possible? with a diff drop of course or will it be "too much lift" ?? anyone? anyone?
  2. Dec 4, 2013 at 11:33 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The 5100s will provide 2.5" of lift. You can run a couple of 1/4" Top-spacers to get you close to 3" without going over. Then for the rear you can run the 2" aal like you were thinking.
  3. Dec 4, 2013 at 7:45 PM
    Toyota05zack
    Zack
    Massachusetts
    05 reg. cab 4x4
    thank you very much! would you suggest this lift over OME??
  4. Dec 4, 2013 at 9:04 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Stacking lifts is not recomended.....worst idea ever. Loading the stock coils like that is going to make for a crappy ride.
