Before I buy the OME lift.
Discussion in 'Toytec Lifts' started by Toyota Truck, Feb 7, 2011.
  1. Feb 7, 2011 at 7:21 AM
    Toyota Truck
    Toyota Truck [OP] Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    I wanted to know If I needed to buy the longer U-bolts for the TSB AAL for the 05-11 toyota tacoma or does it come with the lift kit. Also do I need extended brake lines? I was told by a member on this forum that I didn't. Is there any way you can guarntee I won't have any driveline vibes?
    I plan on buying this. Do I need anything else?
    1. OME lift kit (885 coils) w/TSB AAL
    2. Light Raceing UCAs
  2. Feb 7, 2011 at 7:23 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    IIRC I used my stock U bolts but double checck, you dont need extended brake lines, theres no way to guarentee no vibes besides keeping it stock.
  3. Feb 7, 2011 at 7:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^^ And your gonna need new shocks with those coils.
  4. Feb 7, 2011 at 7:39 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Even with a driveline bearing drop kit from wheelers?
    The kit comes with OME 90000 sport struts and N182 shocks.
    Did any of you have driveline vibes with your lifts?...BTW thanks for the quick replies. :)
  5. Feb 7, 2011 at 7:40 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    And keep in mind it rides alot stiffer after the install. I have a OME setup and it rides like a one ton but of course alot more agile.
    And I don't notice any driveline vibes.
  6. Feb 7, 2011 at 7:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only vibes I ever had were from un ballanced tires.
  7. Feb 7, 2011 at 7:48 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Yeah, I expect that.
    Cool, thanks.
