Behold......the KB Voodoo Cargo Basket - CLOSEOUT SALE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, Aug 9, 2015.
  1. Aug 9, 2015 at 1:28 PM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    This basket requires NO CROSSBARS. It mounts directly to the cleat rails with the supplied T slot nuts and 3/8" knobs.
    Internal dimensions are 5.5" high x 16" wide x 52" wide.
    There will be mounting holes pre-cut for bicycle fork mounts.
    The first one will made early this week. Pic's coming soon.
    NOTE: May work with some canopies. It is up to the purchaser to review the photos of how this mounts, and determine if it will work with their canopy/topper.
    Fits 2nd gen and 3rd gen Tacoma's
  2. Aug 9, 2015 at 1:33 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I like that.
  3. Aug 9, 2015 at 1:35 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Subbed. I like it
  4. Aug 9, 2015 at 1:38 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    In.
    KB Voodoo[OP] likes this.
  5. Aug 9, 2015 at 2:35 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    What do you guys think about a different powder coat color than black?
    I was thinking gunmetal gray.
  6. Aug 9, 2015 at 3:13 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I like it. subbed
  7. Aug 9, 2015 at 3:16 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    subbed.....i like the smoke/grey look.....to match the sport "theme"
  8. Aug 9, 2015 at 3:21 PM
    remery829
    remery829 Well-Known Member
    Eastern NC
    '14 DCSB TRD Offroad
    Some stupid expensive stuff
    This looks like it would fit within a softopper. Would be sweet to have this up against the cab inside the topper for easy access to necessity items.
    MTNHABITOVERLAND likes this.
  9. Aug 9, 2015 at 3:22 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    @KB Voodoo
    What are you thinking for price? ballpark
  10. Aug 9, 2015 at 3:22 PM
    remery829
    Eastern NC
    Is that 5.5" total height or the depth of the basket?
  11. Aug 9, 2015 at 3:22 PM
    Ianp05
    Ianp05 Well-Known Member
    IAN
    DETROIT
    2006 Double Cab 4x4 TRD Sport
    This is sweet!
    Just out of curiosity - What would the weight capacity of this be?
    EDIT: Also - This looks like it might be campertop compatible, yes?
  12. Aug 9, 2015 at 3:24 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Exact
    Exactly what I was thinking. The slope of the sides matches the side of our truck (71 degrees, in case you were wondering).
    I plan to push mine all the way up against the cab. It will be out of the way, but right by the can, making it more handy to put stuff in.
  13. Aug 9, 2015 at 3:25 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    That's the useful height of the basket. It will stick up past the side of the bed by about 6.5".
  14. Aug 9, 2015 at 3:26 PM
    remery829
    Eastern NC
    Badass. I'm gonna go ahead and throw my name in the hat then...
    KB Voodoo[QUOTED][OP] likes this.
  15. Aug 9, 2015 at 3:26 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It should handle the weight of anything you can fit in it.
    Yeppers, it will be topper compatible.
    Fastbilly5 and DrFunker like this.
  16. Aug 9, 2015 at 3:26 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    I would have liked 90 degree edge front and back to keep it boxed. Straight edges and right angles are usually better for packing and securing. Jerry cans, water jugs, tool boxes, pelicans etc. All square(ish) edges.
    Nice concept overall. Great option for folks with canopy. I'd be inclined to mount it at the back within easy reach at the tailgate.
    squint0241 likes this.
  17. Aug 9, 2015 at 3:26 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    can i ask the reasoning being having it above the crossbars? will you be looking at making another version that hangs below? i feel this sits right in my rearview mirror area.
  18. Aug 9, 2015 at 3:28 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    He kind of already makes that.
  19. Aug 9, 2015 at 3:30 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    This ^^
  20. Aug 9, 2015 at 3:31 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    There are already tons of baskets on the market with 90 degree sides. This one will be functional, and look great.
    DrFunker likes this.
