Behold......the KB Voodoo Cargo Basket - CLOSEOUT SALE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, Aug 9, 2015.
  1. Feb 24, 2016 at 1:01 PM
    #321
    diableri
    diableri Well-Known Member
    Central CA
    16' TRD OR DC Auto
    I only need four of these right Chad? One for each rail mount? Figured I'd order them and a few extra bits for whenever it arrives. Thanks again, looking forward to it.
  2. Feb 24, 2016 at 1:27 PM
    #322
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Yes sir. Four will do it.
  3. Mar 1, 2016 at 3:17 PM
    #323
    diableri
    Central CA
    16' TRD OR DC Auto
    Got my basket on today, great stuff Chad; thank you! Totally happy, looks great and does exactly what I need it to do.
    Just a note to anyone else interested in popping on pin torx heads, you'll want 1" length; the 1" 1/4" linked above are the right thread, just a bit too long and back up against the back wall of the rail. Chopped mine off and worked perfectly.
    802coma and KB Voodoo[OP] like this.
  4. Mar 1, 2016 at 3:36 PM
    #324
    CaptainMorgan
    CaptainMorgan Custom headlight retrofits
    Mesa, Arizona
    2014 White Tacoma TRD Sport
    17 inch Black Rhino Rockwell Wheels, BFG 275/70/17 Ko2 Tires, 3 Inch Rough Country Front lift 2 inch Rough Country Rear Lift
    Will you be able to use this with a bedcover?
  5. Mar 19, 2016 at 5:22 PM
    #325
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Should you find yourself in need of some rear-facing lights, here is a possible solution.
    These work lights fit like a champ. Very low profile, screw on from the back. The hole spacing matches up nicely with the @KB Voodoo fork mount slots; only had to drill two holes per. And the carriage bolts along the bottom of the rack allow for easy and neat cable routing. Provided a convenient solution for me.
  6. Mar 25, 2016 at 12:53 PM
    #326
    ThomasMore66
    Dallas/Fort Worth & Durango
    Thought I'd leave this here just FYI. MY old style KBV under my new Extang cover.
    Finally have what I wanted.
    ChadsPride likes this.
  7. Mar 25, 2016 at 3:15 PM
    #327
    el_turks
    el_turks Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    @VooDoo - make one of this big enough to put a 33 spare tire on.....
  8. Mar 25, 2016 at 5:52 PM
    #328
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Use my HD crossbars for that, my man.
  9. Apr 18, 2016 at 4:42 AM
    #329
    802coma
    802coma Well-Known Member
    Caleb
    NEK & Southern VT (Berkshires occasionally)
    '10 Reg Cab 4x4 MT
    Finally putting it to use!
    ChadsPride, Simon's Mom, EDDO and 2 others like this.
  10. May 2, 2016 at 3:18 PM
    #330
    NKYTaco
    NKYTaco Well-Known Member
    Brandon
    South Eastern Indiana
    2014 MGM TRD Pinstripe Edition
    @KB Voodoo I haven't gotten to install mine yet, but build quality is awesome! Cant wait to get it mounted.
  11. May 2, 2016 at 3:49 PM
    #331
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I can't wait to get mounted either.
  12. May 20, 2016 at 11:03 AM
    #332
    802coma
    Caleb
    '10 Reg Cab 4x4 MT
    I order some Torx bolts in order to prevent against theft. As stated before, the 1 inch work great. Here is what I ordered:
    NOTE* These were ordered from http://www.mcmaster.com/
    ChadsPride and KB Voodoo[OP] like this.
  13. Jun 19, 2016 at 5:10 AM
    #333
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Shit. I want it but I'm trying to save money.
    That's not $225 shipped, right?
  14. Jun 19, 2016 at 6:09 AM
    #334
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Nope. Shipping is extra.
  15. Jun 24, 2016 at 10:57 AM
    #335
    AZJEFFRO
    AZJEFFRO Well-Known Member
    Jeff
    Tucson, AZ. USA
    PreRunner TRD Offroad.
    Any idea how much shipping is to 85711 ?
  16. Jun 24, 2016 at 11:10 AM
    #336
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Shipping to AZ is always ridiculous....
    $73 to you (but worth it, IMO)
  17. Jun 24, 2016 at 11:28 AM
    #337
    AZJEFFRO
    Jeff
    Tucson, AZ. USA
    Cool thanks. I want to get a tailgate cap as well.
  18. Jun 24, 2016 at 11:33 AM
    #338
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It might be a little pricey, but you'll be happy.
  19. Jun 24, 2016 at 12:11 PM
    #339
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    If I order today...does it ship today?
    Can you get it here by end of day Monday?
    45174
  20. Jun 24, 2016 at 12:18 PM
    #340
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I wouldn't be able to get it to the post office until tomorrow morning. That means the only way to get it to you by Monday for sure is to send it overnight. That would be expensive.
