Behold......the KB Voodoo Cargo Basket - CLOSEOUT SALE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, Aug 9, 2015.
  1. Aug 10, 2015 at 8:30 PM
    #61
    ThomasMore66
    Dallas/Fort Worth & Durango
  2. Aug 10, 2015 at 8:48 PM
    #62
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    and climb over it to get to the stuff in the front
  3. Aug 11, 2015 at 4:01 AM
    #63
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Crawl under. :bananadance:
  4. Aug 11, 2015 at 4:18 AM
    #64
    ThomasMore66
    Cause it'll have lights.
  5. Aug 11, 2015 at 4:37 AM
    #65
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    If one were so inclined, they could replace three of the T slot nuts with track rollers. Then you would just loosen the one knob with the T slot nut, and easily roll it along the track.
  6. Aug 11, 2015 at 4:53 AM
    #66
    ThomasMore66
    Pic of rollers?
    Donni likes this.
  7. Aug 11, 2015 at 4:58 AM
    #67
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Something along these lines.
    Whitecloud, Fahrenheit and ChadsPride like this.
  8. Aug 11, 2015 at 5:12 AM
    #68
    ThomasMore66
    Something else new to me.
  9. Aug 11, 2015 at 5:12 AM
    #69
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Could you make one like this but invert it so it sits above the wheel wells, and still attaches to the rails? I did see your other one that is deeper that sits inside the wheel wells.
  10. Aug 11, 2015 at 8:42 AM
    #70
    Lomez
    Lomez Well-Known Member
    Lomez
    AZ
    2015 Silver Sky DCSB 4WD
    This is exactly what I was thinking, but I think it IS wide enough to hold my heavy insulated igloo, and the APs can go underneath instead.
    WhiteNemesis[QUOTED] likes this.
  11. Aug 11, 2015 at 8:47 AM
    #71
    OZ-T
    Peter North
    British Columbia
    Limbo down
    How low can you go
    KB Voodoo[QUOTED][OP] likes this.
  12. Aug 11, 2015 at 8:48 AM
    #72
    OZ-T
    Peter North
    British Columbia
    Like
  13. Aug 11, 2015 at 8:55 AM
    #73
    Lomez
    Lomez
    AZ
    Pardon me marking up your drawings. If B (the stated width I assume at the top of the box) is 16", What is A (The width of the bottom flat section)?
    You have created such cool stuff, it is almost overwhelming.
  14. Aug 11, 2015 at 8:57 AM
    #74
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
  15. Aug 11, 2015 at 9:11 AM
    #75
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    A is 12"
    B is 17"
    So it might not work with the small Action Packer, or at least it won't sit flat..
    Lomez[QUOTED] likes this.
  16. Aug 11, 2015 at 9:29 AM
    #76
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    But maybe it will. The bottom of that Action Packer looks like it tapers quite a bit.
  17. Aug 11, 2015 at 9:31 AM
    #77
    Dr_Kevorkian
    Dr_Kevorkian Well-Known Member
    California
    2nd Gen Pyrite Mica AC
    I.........want.............one..............!
    Any idea on what its gonna run price wise?
  18. Aug 11, 2015 at 9:34 AM
    #78
    slc_tacoma
    slc_tacoma Well-Known Member
    SLC, Utah
    2015 Tacoma
    Prices listed earlier in this thread suggest anywhere between 250-300.
  19. Aug 11, 2015 at 9:47 AM
    #79
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Looks like it's going to land on $275 plus shipping.
    It's going to be a thing of beauty with the gun metal gray powder coat.
    slc_tacoma[QUOTED] likes this.
  20. Aug 11, 2015 at 10:11 AM
    #80
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    If the Action Packers fit this may be the solution to my problem!
