Bell housing adapters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheTim11, Oct 27, 2020.
  1. Oct 27, 2020 at 9:20 AM
    TheTim11
    TheTim11 [OP] New Member
    2008 Tacoma 4x4 trd
    Mostly stock
    Hey all, I have a 2008 taco 4.0 4wd that the engine is knocking. Wondering if anyone knows what company’s are out there (if any) that make a bell housing adapter for a Chevy v-8 to my 5AT automatic that’s in my taco already.
    I’m looking at $5k+ to rebuild the original V6. I have 8 Chevy 350 V8 long blocks at home to rebuild, which will be cheaper and more power.
    Any info will be great thank you.
  2. Oct 27, 2020 at 9:35 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    TheTim11[OP] likes this.
  3. Oct 27, 2020 at 9:48 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    As Sumotnk posted only adapter I'm aware of goes the other way, Toyota motor -> chevy trans.
    The Aisin RA60 has a variant that was in the V8 Camarros or so I remember reading somewhere so you might be able to make the manual trans bolt to a LS series but don't know anything about SBC or the auto trans' case bolt pattern.
    You can spend some time poking around here but don't know if you'll find much.
    https://www.advanceadapters.com/
    There's a few LS1 and 3 swaps here but never seen a SBC swapped in, AFAIK the 4.0 makes more than the SBC. I know my numbers are bigger than my buddy's 94 1500 V8.
    :notsure:
    I'd probably just look for a low mile motor from a junkyard and stay "stock" if I were you.
    Anything is possible with enough time money cad and 5 axis.
    Good luck! :thumbsup:
    TheTim11[OP] and SUMOTNK like this.
