Bell housing to exhaust bracket
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Rachelsdaddy, Jun 25, 2023.
  1. Jun 25, 2023 at 6:48 PM
    Rachelsdaddy
    Rachelsdaddy [OP] Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I'm trying to find this dumb bracket. I can make one but really don't have the time or desire.... Do you have one? 99 2.7 auto but I think the manuals are the same. thanksIMG_0605.pngIMG_0604.png
  2. Jun 29, 2023 at 6:55 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Here's the part number for the bracket that bolts to the transmission: 175710C050
    You will also need the clamp part, but I cannot find the number for that. I bet a dealer could if you gave them that first number.
    I just put one on and used a strap clamp to mount to my LCE long tube headers. I keep having issues with the gasket to the Catalytic converter failing, so I'm hoping that it will correct the issue.
  3. Jun 29, 2023 at 8:04 AM
    Rachelsdaddy
    Southern NH
    I have the part number, actually ordered it direct from Japan. the clamp came with the pipe, which I got at Toyota....
  4. Jun 29, 2023 at 8:11 AM
    Rachelsdaddy
    Southern NH
    Im considering welding the convertor to the front pipe... eliminate that gasket...
  5. Jun 29, 2023 at 8:34 AM
    nzbrock
    Noah
    San Marcos, TX
    As long as you can still get the whole thing out, that's not a bad idea. I don't think I could get the long tube header and cat out in one piece. It really needs a flex joint in that area.
  6. Jun 29, 2023 at 9:21 AM
    Rachelsdaddy
    Southern NH
    with the stock down pipe theres plenty of room, Im tired of screwing with that fn gasket... I will defintely be welding it. Im replacing the entire exhaust when the clamp shows up. Down pipe, convertor, Walker Sound FX from there. I recently replaced the manifold with a second gen tube header...
