Bellhousing issue? Is this common?
Discussion in '1st Gen. Tacomas (1995-2004)' started by another_sf_taco, Jan 8, 2021.
  1. Jan 9, 2021 at 10:02 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Able to drive if your real good !! always park on a incline start in 2nd or third .can shift by controlling rpms only have to stop when you get to where your going on the next hill .
    Other then that Not Really
  2. Jan 10, 2021 at 4:13 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Giving this some thought since the Fork just pivots on that ball .
    How could you even get enough leverage to break that piece off it should just Pop off the retainer in the normal course of removing the transmission .
    If one gets rather forceful yanking and pulling things as is sometimes all part of the fun in most cases it is still attached .
    Dalandser likes this.
  3. Jan 10, 2021 at 6:28 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Well I got time on my hands so I am offering my comment / opinon
    Agree with others. Very unlikely that that post was just broken off by itself. If it was broken when you first brought the truck to the shop - you would not be able to drive it easily and there would likely be a loud noise from the bell housing when the engine was running.
    I think it was broken during careless removal.
  4. Jan 10, 2021 at 4:28 PM
    BuelltonTacoma
    BuelltonTacoma Well-Known Member
    2000 Tacoma 4x4 V6 3.4L MT
    This exact thing happened on my truck at 310k. So yeah, this can happen -- I've experienced it.
  5. Jan 10, 2021 at 4:30 PM
    gearcruncher
    Canadain bumper technician
    Any explanation as to how it happened to your truck ?
    Wyoming09 likes this.
  6. Jan 10, 2021 at 4:41 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    What was your symptoms?
  7. Jan 10, 2021 at 4:43 PM
    BuelltonTacoma
    Everything was fine, until it wasn't. I was driving home from work and noticed the clutch was feeling a bit stiffer than usual. At first I thought it was in my head, but after about a dozen stoplights the clutch was really difficult to sink to the floor. I turned off into a neighborhood that parallels the road I usually drive home because I had a feeling something was about to go sideways. Sure enough, next stop sign and I could barely press the clutch in at all. The next one, POP -- clutch hit the floor. I spent the next day replacing the master and slave, but nothing changed -- it was as if the clutch wasn't holding pressure. Bleed the hoses and it would return to normal, then as soon as it was depressed it would stick to the floor. Called my buddy over to get a second opinion, and he noticed that the clutch fork had a lot of play in it. We removed the boot that exits the bellhousing and saw that the fork was snapped off. I had it towed to a mechanic and they replaced the bellhousing. $1200 bucks. The mechanic at the shop I went to told me he had never seen that happen before.
  8. Jan 10, 2021 at 5:20 PM
    gotblika
    Maui
    2015 DCLB Sport 4X4
    So you would have to believe that he’d have more problems than he had especially over the 1,500m trip that was just completed??
  9. Jan 11, 2021 at 12:49 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The transmission in the Tacoma has synchros on 1st and reverse.
    The 1995-2000 R150F has a single-cone synchro on 1st, the 2001-2004 has a triple-cone synchro on 1st. Reverse uses the 5th gear synchro.
    Jeff
  10. Jan 11, 2021 at 4:43 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Rough handling or not I can`t see how you could manage to break that off removing the transmission.
    A bad casting that cracked over a few hundred thousand miles I could understand the crack just propagated over time.
    OP`s looks like it broke all at once
  11. Jun 20, 2023 at 8:09 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    I know this is a couple years old but I wanted to add that this happened to my 2002 at around 210k miles. I had been experiencing difficulty shifting, especially into 1st and reverse and just wrote it off as being the original clutch. One day I looked and noticed the slave cylinder push rod angle didn't look right, pulled the shift fork boot and found the base of the fork pivot could be moved around. Not sure why, but just like the OP the bell housing had cracked where the fork pivot mounts. I'm the original owner, no work has ever been done on the transmission.
