Belstiens 5100 for 2" rear lift
Discussion in 'Suspension' started by Cnasianfire, May 6, 2019.
  1. May 6, 2019 at 6:24 PM
    Cnasianfire
    Cnasianfire [OP] Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    Ok, I'm not stupid and work in IT, but I can't find 5100's for the rear of 2015 with a 2 inch lift. Where can I find them? Ugh!
  2. May 7, 2019 at 4:44 AM
    atrain23
    atrain23 Well-Known Member
    Alex
    New Hampshire
    2016 Tacoma SR5 DCSB V6
    TRD off-road wheels
    I’m pretty sure the 5100s can take the 2 inches of lift. I’ve looked for a specific 2 inch lift size and can’t find it. Headstrong off road sells the 5100 and they have a chart that shows travel tolerance.
  3. May 7, 2019 at 4:48 AM
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    5125 is what you're looking for
  4. May 7, 2019 at 7:04 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Thanks guys, but I don't see anywhere that says that they fit a 2 inch lift. Don't you need a longer one if you have a 2 inch lift vs stock?
  5. May 7, 2019 at 7:06 AM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Because your rear shocks don’t lift the truck?
  6. May 7, 2019 at 7:11 AM
    Cnasianfire
    Charles
    Wilmington, NC
    I am new to suspension, so bare with me. But I thought that the shock had to have a longer travel length with a lift. The guy that had the truck before me, lifted the rear 2 inches, but left the stock shocks on the rear. So it rides pretty rough and seem to be extended pretty far when sitting still on level ground.
  7. May 7, 2019 at 7:20 AM
    toysrgood
    SC
    2011 4x4 Reg Cab
    The description provided for the Bilstein 5125 says that they work well for 2"-3.6" of rear lift.
    You are fine running the 5100's with a lift, but you're right, they will top out (fully extend) sooner and you won't be able to take advantage of any additional travel that your rear suspension may provide.
    Look at the dimensions of each shock. (stock length 8.92" travel)
    14.02-22.94"
    vs (extended, 9.37" travel)
    15.01-24.38"
    So approximately 1" longer collapsed length, and 1.44" longer fully extended.
    Cnasianfire[OP] likes this.
