Belt like squealing sound on hard braking or hitting a bump
Discussion in '1st Gen. Tacomas (1995-2004)' started by Loadout66, Jan 1, 2023.
  1. Jan 1, 2023 at 8:33 AM
    Loadout66
    Loadout66 [OP] Member
    Eastern,TN.
    99 Taco,v6;4wd;2.5" lift.
    2.5 inch lift.Donahoe coilovers in front,Downey leaf springs in rear,4 Runner buckets and console inside,5100 Bilstiens in rear.
    I have a 99 Tacoma v6 4x4 with non-abs front disc brakes. Lately,if I brake hard,even at a low speed,I get what sounds like a belt squealing sound. It is not the disc pad sensorsrubbing the rotrs. I have also heard this sound once in awhile if i hit a dip in the road or are going around a bend. Any thoughts? Again,sounds like a belt squealing.....thanks!
  2. Jan 1, 2023 at 8:50 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Have you checked the tension on your belts? When was the last time you've replaced them?
    You also may want to watch Timmy's video on checking motor mounts and inspect those.
    ArizonaBrian and Bivouac like this.
  3. Jan 1, 2023 at 8:53 AM
    Loadout66
    Eastern,TN.
    Belts feel tight and look good though they are several years old. Motor mounts are new.
  4. Jan 1, 2023 at 8:55 AM
    Loadout66
    Eastern,TN.
    I can crawl down the road and hit them hard and i hear it.
  5. Jan 1, 2023 at 8:56 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    :notsure: Maybe with the engine idling, and truck in park or neutral, try putting a floor jack under a good front lifting point so the wheels are off the ground, and then release the jack and see if you can repeat the sound at a standstill.
  6. Jan 1, 2023 at 1:03 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    New Motor mounts does not mean they have not failed .
    perhaps hardware has come loose .
    Transmission mount?
