belt or a chain?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by linkfeeney, Oct 1, 2008.
  1. Oct 1, 2008 at 7:19 PM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    i have a 09 tacoma. is it a timing belt or chain?
  2. Oct 1, 2008 at 7:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you got the v6?? if so...you got a chain.
  3. Oct 2, 2008 at 9:10 AM
    Red Razor
    Red Razor Well-Known Member
    Greensburg PA
    06 TRD Sport 4X4
    +1. I think you can even see it though the oil fill tube.
  4. Oct 2, 2008 at 9:27 AM
    steelerfan7p
    steelerfan7p My other car is a Bugatti
    Yes
    Fairmont, WV (1 Hour South of the City of Champi
    Non-TRD, Non-SR5, Non- Prerunner
    Rear Leaf Spring TSB, Metra IPod Adapter, AFE Pro Dry S Air Filter, I was added to the truck to make it better, so does that count as a Mod?
    When is it recommended to change a time chain? Isn't it 100,000 mi?
  5. Oct 2, 2008 at 9:42 AM
    uuc328
    uuc328 Well-Known Member
    So. Arlington, Texas
    '07 FJC fender crack edition
    i am almost certian that there is a service life for the chain but most people never change them. i have had two 200K+ vehicles with chains that were never serviced
  6. Oct 2, 2008 at 9:54 AM
    1-3-2-4 Squirrel Mincer
    Ithaca, NY
    06 Titan King Cab
    A.R.E. tonneau cover
    The four banger is a chain as well, Tsubaki I might add.
  7. Oct 2, 2008 at 12:52 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    i have a v6.... I guess I never have to change that again uh?!
  8. Oct 2, 2008 at 1:08 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    There isn't any mention of it in the service manual up to 120k miles at least.
  9. Oct 2, 2008 at 1:12 PM
    Ithaca, NY
    06 Titan King Cab
    The good thing about timing chain is that it typically won't break. Belts are another story, so you change them to insure you never do engine damage. As a chain elongates, you may notice poor performance. In severe cases, the tensioner can over-extend and the chain may contact other engine components, which is obviously not desirable. Given that it is roller chain, 120,000 should be adequate.
  10. Oct 2, 2008 at 2:54 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    ummm, I need to look at the manual.... u telling me we have to change the chain at 120k? that means I have to change the water pump no?
  11. Oct 2, 2008 at 2:58 PM
    TacoCo
    Colorado
    The manual only covers up to 120k miles and there's no mention of it, anywhere.
  12. Oct 2, 2008 at 4:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have never had to replace a timeing chain in a Toyota motor. I had almost 200 thou on my 'ol 22re and decided to change the chain. Chain was fine, and all the work I did was for nothing. I contacted Toyota about this a year and a half ago asking about the chain in the 1GR-FE, and they said that the chain is a "lifetime" chain. That threw my BS flag RIGHT UP, and I decided to dig a bit deeper on my own. Turns out, They were right..........kinda. The Toyota truck engines are engineered to have a 250,000 mile service life before requiring "major" work. The timeing chain is included in this 250,000 mile service life. ALSO, I havent been able to find a "duty cycle" rating for this engine. Its very rare that a Toyota engine requires a "Major" overhaul at 250,000 miles. I have many friends that have MUCH more than that on their engines. A buddy of mine is getting ready to turn 600,000 miles on his Tacoma, and he has never replaced his timing chain. And it seems to run just fine. :)
  13. Oct 2, 2008 at 4:49 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    so i guess i have timing chain then? word up dawg!
  14. Nov 5, 2008 at 7:41 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    ^Belt.
  15. Nov 5, 2008 at 8:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....timing belt...needs replacing at 90k. thats when i'll do mine, along with water pump, seals and my other belts too. good insurance!!:)
  16. Nov 5, 2008 at 9:53 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you do change the chain... you should do the waterpump at the same time. It's not necessary, but it's a lot of work. It'd suck to have the waterpump fail 20k later and have to tear the chain back off to replace a pump. I changed out the pump on my vr-4 at 60k when the belt was done... not because it was needed but because it's a $120 insurance policy to get you through to the next change.
  17. Nov 5, 2008 at 10:50 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    The water pump on a 1GR-FE V6 engine is an externally mounted water pump. The pump is run by the external serpentine V-ribbed belt not by the timing chain.
  18. Nov 5, 2008 at 10:53 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Ah well then, no point in doing it :p Most vehicles are usually driving it with the t-belt/chain. Didn't look at the taco's. (Granted, at 7k miles on the odo I had awhile to do it :p) Thanks for the info.
  19. Nov 5, 2008 at 11:00 PM
    BeefTaco
    That is one thing Toyota has done right lately by mounting the water pump on the outside of the there motors makes replacement a lot less time consuming. :)
  20. Nov 6, 2008 at 4:45 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    the timing belt is a pain then i gotta do the water pump too...
    no offical word from toyota is chain or belt?
