Belt Squeak
Discussion in '4 Cylinder' started by Scosh, Oct 20, 2009.
  1. Oct 20, 2009 at 4:35 AM
    Scosh
    Scosh [OP] Well-Known Member
    Scotty
    New Iberia
    02 Prerunner SR5
    Bilstein 5100's all around, Limo Tinted windows, Moto Metal 951 wrapped in Revo 2's 265/70/16, clear corners, dual Magnaflow muffler, Turn signal mod, more to come...
    My belt started squeaking last week and it is annoying. I tried spraying it with a belt conditioner and it stops the squeak for a good while. It doesnt squeak the whole time either, it starts to squeak at random moments. Whenever it does start to squeak it only does so above 30mph. Can anyone help me with this problem? Is it even my belt squeaking? If you need anymore information just leave a message and I will get back to you as soon as I get back from school.
  2. Oct 20, 2009 at 7:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Check the belt tension.....
    Check the belt condition...
    Check pulleys...
    Check bearings on the pulleys....
  3. Oct 20, 2009 at 1:45 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    x2, Most likely loose.
    and the Belt dressing is only made for V style belts. not flat ribbed kind.
  4. Oct 20, 2009 at 1:57 PM
    Scosh
    Scotty
    New Iberia
    02 Prerunner SR5
    Thanks guys. Everything is fine so far, I just changed the belt because it looked worn out.
  5. Oct 20, 2009 at 6:57 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    did that fix the problem?
  6. Oct 20, 2009 at 7:01 PM
    Scosh
    Scotty
    New Iberia
    02 Prerunner SR5
    So far there hasnt been any squeaks from the new belt, but I will see what happens as time goes by.
  7. Oct 20, 2009 at 7:07 PM
    beastlytaco
    Ian
    08 Access Cab SR5
