Belt Squeal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by F-125Racer, Mar 3, 2018.
  1. Mar 3, 2018 at 6:06 PM
    F-125Racer
    F-125Racer [OP] Well-Known Member
    Arkansas
    09,DC,TRD Sport, 4WD, TRD S/C
    Alright TW friends, I've got a 2009 DC/SB Sport with a crazy belt squeal. I have replaced all the idlers, tensioner, belts, but it's still there. I can rub a bar of soap on the groove side of the belt and it stops for a bit, but then comes right back. I've tried the stock belt, Poly Rib GT, and one other brand I can't remember, but no change. After every new belt, it takes 2-5 weeks for the squeal to come back. After looking more closely, it looks like the crank pulley may be about 1/8" to 3/16" misaligned toward the front. After eliminating everything else, this looks to be the culprit. I've read everything on TW and everywhere else I could find about Taco and FJ belt issues.
    Has anyone else seen this??
  2. Mar 3, 2018 at 7:01 PM
    Pigpen
    Dan
    Northwest Montana
    The air conditioner condenser clutch is probably seized. If it was the water pump pulley,you would've over heated. If it was the alternator, your battery light would be on. If it was the starter, it wouldn't start.
  3. Mar 3, 2018 at 7:08 PM
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
    Just a possibility - had this issue immediately after changing the belt a couple of years ago during the cold part of the year. Took the belt off and turned it so it was rotating the opposite direction and the squeal disappeared (found the idea on one of the Tundra forums and took a chance).
    MuddyJackson likes this.
  4. Mar 3, 2018 at 7:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the balancer looks out of alignment some times that means it's coming apart. The rubber damper becomes separated and the crank pulley starts walking off the end of the crankshaft
  5. Mar 3, 2018 at 7:54 PM
    Pigpen
    Dan
    Northwest Montana
    @MuddyJackson
  6. Mar 4, 2018 at 7:33 PM
    F-125Racer
    Arkansas
    A/C clutch isn't locked up. and the pulley isn't coming apart.
  7. Mar 5, 2018 at 8:46 AM
    MuddyJackson
    MuddyJackson Well-Known Member
    Eva
    Billings, Montana
    2006 Toyota Tacoma Base 4x4 6 speed
    Hasn't sqealed for a while now ... fingers crossed...
  8. Mar 5, 2018 at 3:00 PM
    Pigpen
    Dan
    Northwest Montana
    :fingerscrossed:
    MuddyJackson[QUOTED] likes this.
