Belt Squealing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Que, Jun 30, 2016.
  1. Jun 30, 2016 at 6:12 PM
    Que
    Que [OP] Member
    Scott
    Searching
    So, I found a first gen Tacoma I'm looking to buy. But, its in another city. I'm being told that there's a squealing sound (belt?) when first starting the truck. It goes away after a bit. Also, it only happens when starting truck with the a/c on.
    Can anyone diagnose from afar? Alternator Belt? Any other possibilities?
    Any help would be greatly appreciated. Thanks.
  2. Jun 30, 2016 at 8:28 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    engine size would br helpful, but more then likely belt is out of tension.
  3. Jun 30, 2016 at 8:30 PM
    Que
    Que [OP] Member
    Scott
    Searching
    2.7L 4-cyl year: 2003
  4. Jun 30, 2016 at 8:34 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    something like described is like, 99% something to do with the belts. and even more so because you stressed it had to do with the AC. so like 99.99% sure. don't worry. when you get it just change all the belts and see when the timing has been done.
  5. Jun 30, 2016 at 8:37 PM
    Que
    Que [OP] Member
    Scott
    Searching
    Thanks, when you say all belts, you mean a/c, alternator, and power steering, right? And inquire about timing belt.... am I missing any?
  6. Jun 30, 2016 at 10:34 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The 4-banger has a timing CHAIN :D
    One of the 3 accessory belts is likely a little loose, causing the squeal.
    Very minor issue, unless they are lying to you.
  7. Jul 5, 2016 at 5:41 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Could also be the A/C idler pulley bearing- Been there ,Done that!
  8. Jul 5, 2016 at 1:11 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Like said, 3 belts, 1 for AC, 1 for power steering and 1 for alternator.
    The AC and ps belts each have manually adjustable tension via an idler pulley. The alternator itself rotates to adjust the tension on that belt.
    I replaced all 3 belts and 2 idler pulleys on my 2.7l Tacoma as they would squeal a bit at start up, having the AC on puts additional load on that belt and will make it more likely to squeal, or squeal louder.
    It was relatively cheap to buy 3 belts and 2 idler pulleys, $150-200 for it all. If you can turn a wrench you can change them out.
  9. Jul 5, 2016 at 5:29 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Belt Squeal, eh? Can you describe the squeal?
