Belt Tensioner Noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tsb, Jul 3, 2022.
  1. Jul 3, 2022 at 1:48 PM
    tsb
    tsb [OP] 2018 National Champions
    Clemson Tigers
    '14 4X4 DBCSB TRD OR
    N-FAB nurfs, ARE cover, Gentex mirror, 20% tint
    my all stock ‘14 4L w/ 140k just started a noise from drive belt area.
    i changed the belt and upper right pulley. all pulleys checked out by hand.
    p.s. my 140k belt did not have a single crack.
    so what’s my next move?
    1. replace the tensioner asy?
    2. replace alternator?
    3. replace the other pulleys?
    my vids
    https://youtu.be/IFy4xzva-ak
    https://youtu.be/LzPqrNyhLww
    another guy’s experience…
    https://youtu.be/V418wOYshCI
  2. Jul 3, 2022 at 2:17 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Either go buy a cheap harbor freight mechanic stethoscope or use a long screwdriver to listen while touching the bolt of each component with engine running to locate the noise.
  3. Jul 3, 2022 at 3:59 PM
    tsb
    Clemson Tigers
    alright you are the man - used a pipe and best guess is the sound is from the alternator. the sound from the alternator is consist with the noise. all idlers are consist and same as the new one I replaced.
    denso reman ordered..
    Alexely999, TnShooter and Goldwrench like this.
  4. Jul 5, 2022 at 5:44 PM
    tsb
    Clemson Tigers
    @Wattapunk alternator fixed it. thanks again for the tip.
    wi_taco and Wattapunk like this.
