belt, tensioner & pulley, and idler pulley. part numbers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glamis, Oct 8, 2018.
  1. Oct 9, 2018 at 8:39 AM
    Glamis
    Glamis [OP] date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    thanks for the info. I did my 1st belt from the bottom. What is so hard about the tensioner?
    AR15xAR10[QUOTED] likes this.
  2. Oct 9, 2018 at 9:30 AM
    tacobender
    tacobender Member
    texas
    08 Reg. Cab, work in progress
    just by chance, would these parts #'s be good for an '08, 2.7L, 4-cyl, base model?
  3. Oct 9, 2018 at 12:09 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    oh man.. that was a while ago.. I'm trying to remember, but I dont think I needed anything specific. I do remember it being a PITA tho, (for multiple reasons) and I ended up replacing the entire tensioner anyways. I'll poke around some more and see if I still have any pictures or write-ups.
  4. Oct 9, 2018 at 12:19 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ok, I looked through my old posts. I swapped the bearing itself so I wouldnt have to remove the entire tensioner and AC compressor, etc that is involved with the standard replacement. I ended up still having the squeal until the truck fully warmed up, so I ended up swapping the entire tensioner again later and it solved my issue. The tensioner itself was at fault for my scenario, but if you just need to swap the bearing, it is possible.
    AR15xAR10 likes this.
  5. Oct 9, 2018 at 12:22 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Just change the bearing in the tensioner pulley. Go to an Industrial maintenance supplier near your local industrial wasteland and they should be able to get one for you. Just give them the PN that @Chuy listed above.
  6. Oct 9, 2018 at 12:56 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    i remembered you tried doing the pulley first....i do know its reverse thread as well.....
  7. Oct 9, 2018 at 12:57 PM
    AR15xAR10
    refer to this:
  8. Oct 10, 2018 at 11:55 AM
    Glamis
    ok thanks for the info. I'm going to do it all. just have to set aside the weekend
  9. Oct 11, 2018 at 12:15 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    A press is handy, along with assorted sizes of sockets and cups from a BJ kit or another pulley.
    On utube, you'll see some DIY'ers successfully use a hammer and others use a hex bolt and washer.
    The important thing is pressing the new bearing into the pulley by the outside edge of the bearing. This keeps the stress off the bearings. If you press in the middle, you'll mess it up. It's OK to press in the middle to remove the bearing, but not to install it. You can use the old bearing to press the new one into place; but again, press on the outside. If you use a bolt/nut to press the new bearing, use washers wide enough to 'grab' the outside edge of the new bearing. Here is where the old bearing come in handy because as the top of the bearing becomes flush with the pulley, anything wider than the outside edge of the new bearing will prevent it from seating fully into the pulley.
  10. Oct 11, 2018 at 1:00 AM
    Chuy
    Lakeside, CA
    Silver Taco
    TheDevilYouLove likes this.
  11. Oct 11, 2018 at 2:36 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I used a c-clamp, 27ish mm socket, 2 pieces of steel box tube, and the edge of a table to form a makeshift press. Just prop it up on the steel as wood will absorb a lot of the force, then simply press it out and put the new one in. Took 10 mins once you get the pulley out. I found the hardest part of the job to be putting the new serpentine belt on. Turns out, this job is a lot easier if you go up from the bottom and crank the tensioner from down there, and have a second person slip the belt over the PS pulley from the top as the last pulley.
  12. Feb 14, 2021 at 6:14 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Thanks for the pn’s ! I have 124k on my belt , I was thinking this might be a good maint. Item to do . Is is necessary to do the pulleys ? Or just a good idea to have done
  13. Feb 15, 2021 at 7:30 AM
    AR15xAR10
    always do the pulleys with the belts for the best results :thumbsup:
  14. Feb 15, 2021 at 9:21 AM
    igno1tus
    Ok thanks ! How about water pump too ?
  15. Feb 15, 2021 at 10:02 AM
    #35
    AR15xAR10
    Shouldnt have to worry about that one. I dont think it has a bearing...
  16. Feb 15, 2021 at 4:25 PM
    #36
    igno1tus
    Wow really , I always thought/heard it has to be done also
  17. Feb 15, 2021 at 6:33 PM
    #37
    AR15xAR10
    Not on the 4.0s, at least not that i have ever been made aware of
    igno1tus[QUOTED] likes this.
  18. Dec 16, 2022 at 10:15 AM
    #38
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    These parts you listed are all just pulleys/ a belt, and not the tensioner assembly as well? I’m about ready to order pulleys upon recommendation from a friend.
    Thanks Brian
  19. Dec 16, 2022 at 1:34 PM
    #39
    Chuy
    Lakeside, CA
    Silver Taco
    @Pibbles99 The tensioner part # refers to the tensioner assembly. If you google the part #, you’ll see the assembly.
    In many cases it’s the bearing in the tensioner pulley that only needs replacing but Toyota doesn’t offer it separately. The tensioner bearing size is 17X40X17.5 (bearing types 5203-2NS, 5203-2NSL, or 5203-2RS); to my knowledge only Febest offers a pulley/bearing combination, # 0187-GRJ200.
    Taco 422 and AR15xAR10 like this.
  20. Dec 17, 2022 at 9:42 AM
    #40
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    I replaced all of my pulleys, belt, and alternator a couple of weeks ago.
    I ordered the Gates tensioner assembly, since you can’t just order the pulley. However I did not install the entire thing. It looked like a real pain. Instead I removed the pulley from the new part and replaced the old one. Working great and no noises.
    it is definitely cheaper to just replace the bearings. I used new parts to save on time instead.
    Taco 422 and Pibbles99 like this.
